[GRASS-user] Interpreting r.watershed accumulation map
    Laurent C.
    lrntct at gmail.com
    Tue Oct 11 13:19:31 PDT 2016
Richard,
It seems to be a problem from within the temporal framework. I never
had this specific problem before, but I've run into some other obscure
errors using TGRASS.
Are other temporal commands (t.list, t.create...) working properly?
Laurent
2016-10-11 13:38 GMT-05:00 Rich Shepard <rshepard at appl-ecosys.com>:
> On Tue, 11 Oct 2016, Laurent C. wrote:
>> - Your rainfall rate is very small.
> Laurent,
>   Changed rain to 10 mm/h, time to 2 hrs with 5 min steps. Specified mapset
> for DEM map (be_cropped) as it's not in the analyses mapset.
>> - By setting bctype=4 and bcvalue=0 on all your region, you're forcing
>> a water depth of zero everywhere. For a start, you can drop those
>> parameters.
>   Removed both bctype and bcvalue.
>> About the problem you encounter. Since GRASS does not support python3
>> (AFAIK), Itzï is only tested with python 2.7. It is strange that it
>> installed with python3. To force the installation with python2, you
>> can run the following command:
>> $ pip2 install itzi --user
>   Yes, now itzi is installed for both python2 and python3.
>   There is an issue with the time-space databases that prevent the
> simulation from running:
>> itzi run itzi-param.txt
> Starting simulation of itzi-param.txt... WARNING: Error during execution:
> Traceback (most recent call last):
>   File "/usr/lib/python2.7/site-packages/itzi/itzi.py", line 183, in
> sim_runner_worker
>     sim_runner.run()
>   File "/usr/lib/python2.7/site-packages/itzi/itzi.py", line 90, in run
>     sim_param=self.conf.sim_param)
>   File "/usr/lib/python2.7/site-packages/itzi/simulation.py", line 77, in
> __init__
>     self.gis.read(self.in_map_names)
>   File "/usr/lib/python2.7/site-packages/itzi/gis.py", line 187, in read
>     elif self.name_is_stds(self.format_id(map_name)):
>   File "/usr/lib/python2.7/site-packages/itzi/gis.py", line 138, in
> name_is_stds
>     if tgis.SpaceTimeRasterDataset(name).is_in_db():
>   File
> "/usr/local/grass-7.3.svn/etc/python/grass/temporal/abstract_dataset.py",
> line 368, in is_in_db
>     return self.base.is_in_db(dbif)
>   File "/usr/local/grass-7.3.svn/etc/python/grass/temporal/base.py", line
> 315, in is_in_db
>     dbif.execute(sql, mapset=self.mapset)
>   File "/usr/local/grass-7.3.svn/etc/python/grass/temporal/core.py", line
> 981, in execute
>     self._create_mapset_error_message(mapset)))
>   File
> "/usr/local/grass-7.3.svn/etc/python/grass/pygrass/messages/__init__.py",
> line 271, in fatal
>     sys.exit(1)
> SystemExit: 1
> Simulations complete. Elapsed times: itzi-param.txt: 0:00:00 Total: 0:00:00
> Average: 0:00:00
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
