[GRASS-user] Problem in running r.basin
Priscilla_I
isacco.silvia at gmail.com
Fri Oct 14 05:33:55 PDT 2016
Thanks for your answers, here the command line I run
r.basin map=Ghiandone_DEM at Silvia prefix=out coordinates=368450.0,4954025.0
dir=Silvia threshold=1000 --overwrite
and these are my input raster info
| Map: Ghiandone_DEM at Silvia Date: Fri Sep 02 12:32:06 2016
| Mapset: Silvia Login of Creator: Silvia
| DataBase: C:\Users\Silvia\Desktop\Grass
| Title: ( Ghiandone_DEM )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 888
| Columns: 1047
| Total Cells: 929736
| Projection: UTM (zone 32)
| N: 4965768.6398801 S: 4943886.74090327 Res: 24.64177813
| E: 379279.66825865 W: 353479.72655961 Res: 24.64177813
| Range of data: min = 0 max = 2550
| Data Description:
| generato da r.in.gdal
| Comments:
| r.in.gdal input="C:\Users\Silvia\Desktop\Grass\Piemonte\Silvia\Ghian\
| done_DEM.tif" output="Ghiandone_DEM" memory=300 offset=0
(Fri Oct 14 10:11:48 2016) Comando terminato (0 sec)
I tried with Stefan's command line but unfortunately I didn't solve my
problem.
2016-10-14 2:45 GMT+02:00 SBL [via OSGeo.org] <
ml-node+s1560n5290654h81 at n6.nabble.com>:
> Hi Priscilla,
> I guess the problem is that you run g.region both with the –a flag and the
> align option.
> Se: https://grass.osgeo.org/grass70/manuals/g.region.html
> Please try:
> g.region -p raster=out_Ghiandone_DEM_strahler at Silvia
> align=out_Ghiandone_DEM_strahler at Silvia
> or even just:
> (both commands should give the same result).
> I have seen quite some confusion around the –a flag (e.g. it has been used
> in Processing in QGIS in a unsuitable way for quite some time).
> Maybe the manual should be improved by:
> 1) altering the flag description and
> 2) adding examples for aligning the region to
> a. another raster map
> b. a user given resolution / map resolution
> Flag description could be e.g.:
> “Adjusted to be even multiples of the resolution in raster or res option”
> instead of the current:
> “Align region to resolution (default = align to bounds, works only for 2D
> resolution)”
> BTW, is there any case where it makes sense to specify both –a flag and
> align option? If not, both could be made mutually exclusive in order to
> avoid such confusion?
> Finally, two possible examples for the manual of g.region, which might
> help to make that a bit more clear:
> # Set region extent to a vector map and align resolution to an existing
> raster map
> g.region –p vector=soils align=elev_state_500m
> # Define region to align resolution to be an even multiple of the
> resolution specified by the user
> g.region –pa vector=soils res=100
> Kind regards,
> Stefan
> *From:* grass-user [mailto:[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5290654&i=0>] *On Behalf Of *Margherita
> Di Leo
> *Sent:* 13. oktober 2016 18:18
> *To:* Priscilla_I <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5290654&i=1>>
> *Cc:* GRASS user list <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5290654&i=2>>
> *Subject:* Re: [GRASS-user] Problem in running r.basin
> Hi,
> On Thu, Oct 13, 2016 at 4:51 PM, Priscilla_I <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5290654&i=3>> wrote:
> Hi,
> I'm a new grass user, running "r.basin" module for Grass 7.0.4 on Windows
> 10, I get this error message "ERROR: Region resolution and raster map
> <out_Ghiandone_DEM_strahler> resolution differs. Run 'g.region
> raster=out_Ghiandone_DEM_strahler' to set proper region resolution."
> I'm using a map in projected coordinates, and I align region with the
> raster
> g.region -p -a raster=out_Ghiandone_DEM_strahler at Silvia
> projection: 1 (UTM)
> zone: 32
> datum: wgs84
> ellipsoid: wgs84
> north: 4965768.6398801
> south: 4943886.74090327
> west: 353479.72655961
> east: 379279.66825865
> nsres: 24.64177813
> ewres: 24.64177813
> rows: 888
> cols: 1047
> cells: 929736
> raster info are
> Map: out_Ghiandone_DEM_strahler at Si Date: Thu Oct 13 11:31:23 2016
> | Location: Piemonte
> | Title: ( out_Ghiandone_DEM_strahler )
> | Timestamp: none
> | Data Type: CELL
> | Rows: 888
> | Columns: 1047
> | Total Cells: 929736
> | Range of data: min = 1 max = 4
> | Data Description:
> | generato da r.stream.order
> | Comments:
> | r.stream.order stream_rast="out_Ghiandone_DEM_stream_e"
> direction="o\
> | ut_Ghiandone_DEM_drainage_e" strahler="out_Ghiandone_DEM_strahler"
> h\
> | orton="out_Ghiandone_DEM_horton" shreve="out_Ghiandone_DEM_shreve"
> h\
> | ack="out_Ghiandone_DEM_hack" memory=300
> Any ideas? Thanks in advance!
> What is the exact r.basin command line that you run? Can you post also
> r.info of the DEM that you use as input?
> Margherita Di Leo
> grass-user mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5290654&i=4>
> http://lists.osgeo.org/mailman/listinfo/grass-user
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Problem-in-running-
> r-basin-tp5290587p5290654.html
> To unsubscribe from Problem in running r.basin, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5290587&code=aXNhY2NvLnNpbHZpYUBnbWFpbC5jb218NTI5MDU4N3w3Mjk2MDM5MDE=>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-in-running-r-basin-tp5290587p5290740.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161014/3b65f4dc/attachment-0001.html>
