[GRASS-user] Problem in running r.basin
    Priscilla_I
    isacco.silvia at gmail.com
    Fri Oct 14 07:59:44 PDT 2016
I removed the old output and launched the command but now it gets this error
ERROR: option <output>: <Silvia\out_Ghiandone_DEM_outlet_coors.txt> exists.
To overwrite, use the --overwrite flag
2016-10-14 15:43 GMT+02:00 margherita [via OSGeo.org] <
ml-node+s1560n5290752h19 at n6.nabble.com>:
> Hi,
> On Fri, Oct 14, 2016 at 2:33 PM, Priscilla_I <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5290752&i=0>> wrote:
>> Hi,
>> Thanks for your answers, here the command line I run
>> r.basin map=Ghiandone_DEM at Silvia prefix=out
>> coordinates=368450.0,4954025.0 dir=Silvia threshold=1000 --overwrite
> I think the problem lies in the "overwrite", which is not handled by
> r.basin. Try to remove all your output map, then set the region on the DEM
> and then run r.basin, and let us know.
>> and these are my input raster info
>>  | Map:      Ghiandone_DEM at Silvia           Date: Fri Sep 02 12:32:06
>> 2016    |
>>  | Mapset:   Silvia                         Login of Creator: Silvia
>>  | Location: Piemonte
>>  | DataBase: C:\Users\Silvia\Desktop\Grass
>>  | Title:     ( Ghiandone_DEM )
>>  | Timestamp: none
>>  |   Type of Map:  raster               Number of Categories: 0
>>  |   Data Type:    CELL
>>  |   Rows:         888
>>  |   Columns:      1047
>>  |   Total Cells:  929736
>>  |        Projection: UTM (zone 32)
>>  |            N: 4965768.6398801    S: 4943886.74090327   Res:
>> 24.64177813    |
>>  |            E: 379279.66825865    W: 353479.72655961   Res: 24.64177813
>>  |   Range of data:    min = 0  max = 2550
>>  |   Data Description:
>>  |    generato da r.in.gdal
>>  |   Comments:
>>  |    r.in.gdal input="C:\Users\Silvia\Desktop\Grass\Piemonte\Silvia\Ghian\
>>  |    done_DEM.tif" output="Ghiandone_DEM" memory=300 offset=0
>> (Fri Oct 14 10:11:48 2016) Comando terminato (0 sec)
>> I tried with Stefan's command line but unfortunately I didn't solve my
>> problem.
>> 2016-10-14 2:45 GMT+02:00 SBL [via OSGeo.org] <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5290740&i=0>>:
>>> Hi Priscilla,
>>> I guess the problem is that you run g.region both with the –a flag and
>>> the align option.
>>> Se: https://grass.osgeo.org/grass70/manuals/g.region.html
>>> Please try:
>>> g.region -p raster=out_Ghiandone_DEM_strahler at Silvia
>>> align=out_Ghiandone_DEM_strahler at Silvia
>>> or even just:
>>> (both commands should give the same result).
>>> I have seen quite some confusion around the –a flag (e.g. it has been
>>> used in Processing in QGIS in a unsuitable way for quite some time).
>>> Maybe the manual should be improved by:
>>> 1)      altering the flag description and
>>> 2)      adding examples for aligning the region to
>>> a.      another raster map
>>> b.      a user given resolution / map resolution
>>> Flag description could be e.g.:
>>> “Adjusted to be even multiples of the resolution in raster or res
>>> option” instead of the current:
>>> “Align region to resolution (default = align to bounds, works only for
>>> 2D resolution)”
>>> BTW, is there any case where it makes sense to specify both –a flag and
>>> align option? If not, both could be made mutually exclusive in order to
>>> avoid such confusion?
>>> Finally, two possible examples for the manual of g.region, which might
>>> help to make that a bit more clear:
>>> # Set region extent to a vector map and align resolution to an existing
>>> raster map
>>> g.region –p vector=soils align=elev_state_500m
>>> # Define region to  align resolution to be an even multiple of the
>>> resolution specified by the user
>>> g.region –pa vector=soils res=100
>>> Kind regards,
>>> Stefan
>>> *From:* grass-user [mailto:[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5290654&i=0>] *On Behalf Of *Margherita
>>> Di Leo
>>> *Sent:* 13. oktober 2016 18:18
>>> *To:* Priscilla_I <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5290654&i=1>>
>>> *Cc:* GRASS user list <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5290654&i=2>>
>>> *Subject:* Re: [GRASS-user] Problem in running r.basin
>>> Hi,
>>> On Thu, Oct 13, 2016 at 4:51 PM, Priscilla_I <[hidden email]
>>> <http:///user/SendEmail.jtp?type=node&node=5290654&i=3>> wrote:
>>> Hi,
>>> I'm a new grass user, running "r.basin" module for Grass 7.0.4 on Windows
>>> 10, I get this error message "ERROR: Region resolution and raster map
>>> <out_Ghiandone_DEM_strahler> resolution differs. Run 'g.region
>>> raster=out_Ghiandone_DEM_strahler' to set proper region resolution."
>>> I'm using a map in projected coordinates, and I align region with the
>>> raster
>>> g.region -p -a raster=out_Ghiandone_DEM_strahler at Silvia
>>> projection: 1 (UTM)
>>> zone:       32
>>> datum:      wgs84
>>> ellipsoid:  wgs84
>>> north:      4965768.6398801
>>> south:      4943886.74090327
>>> west:       353479.72655961
>>> east:       379279.66825865
>>> nsres:      24.64177813
>>> ewres:      24.64177813
>>> rows:       888
>>> cols:       1047
>>> cells:      929736
>>> raster info are
>>> Map:      out_Ghiandone_DEM_strahler at Si  Date: Thu Oct 13 11:31:23
>>> 2016    |
>>>  | Location: Piemonte
>>>  | Title:     ( out_Ghiandone_DEM_strahler )
>>>  | Timestamp: none
>>>  |   Data Type:    CELL
>>>  |   Rows:         888
>>>  |   Columns:      1047
>>>  |   Total Cells:  929736
>>> 24.64177813
>>>  |   Range of data:    min = 1  max = 4
>>>  |   Data Description:
>>>  |    generato da r.stream.order
>>>  |   Comments:
>>>  |    r.stream.order stream_rast="out_Ghiandone_DEM_stream_e"
>>> direction="o\
>>>  |    ut_Ghiandone_DEM_drainage_e" strahler="out_Ghiandone_DEM_strahler"
>>> h\
>>>  |    orton="out_Ghiandone_DEM_horton" shreve="out_Ghiandone_DEM_shreve"
>>> h\
>>>  |    ack="out_Ghiandone_DEM_hack" memory=300
>>> Any ideas? Thanks in advance!
>>> What is the exact r.basin command line that you  run? Can you post also
>>> r.info of the DEM that you use as input?
>>> Margherita Di Leo
>>> grass-user mailing list
>>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5290654&i=4>
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> If you reply to this email, your message will be added to the discussion
>>> below:
>>> http://osgeo-org.1560.x6.nabble.com/Problem-in-running-r-bas
>>> in-tp5290587p5290654.html
>>> To unsubscribe from Problem in running r.basin, click here.
>>> NAML
>>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
>> View this message in context: Re: Problem in running r.basin
>> <http://osgeo-org.1560.x6.nabble.com/Problem-in-running-r-basin-tp5290587p5290740.html>
>> Sent from the Grass - Users mailing list archive
>> <http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html> at
>> Nabble.com.
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5290752&i=1>
> Margherita Di Leo
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5290752&i=2>
> below:
> r-basin-tp5290587p5290752.html
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5290587&code=aXNhY2NvLnNpbHZpYUBnbWFpbC5jb218NTI5MDU4N3w3Mjk2MDM5MDE=>
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-in-running-r-basin-tp5290587p5290758.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161014/7000ea46/attachment-0001.html>
