[GRASS-user] I can not get expected value with r.mapcalc
Micha Silver
Micha at arava.co.il
Fri Oct 14 13:37:52 PDT 2016
My understanding of the format for the if() operator with 4 parameters is
that the result is the third parameter only when the first parameter equals
zero. The GRASS MASK in your expression probably has only values of 1 and
null, so the result will always be either parameter 1, or null.
In addtion, r.mapcalc would honor the MASK anyway, so it's not necessary to
include it in the expression.
Looking at your expression, the second parameter gives a boolean result, so
maybe the following might give you what you want:
(Also watch out map names with a dot '.')
r.mapcalc "pr2_pass00 = if (curvt_cat == 1 && curvp_cat == 3 && asp_cat ==
3 && slp_cat == 1 && jeo == 6 ,51, null() )" --overwrite
View this message in context: http://osgeo-org.1560.x6.nabble.com/I-can-not-get-expected-value-with-r-mapcalc-tp5290749p5290795.html
Sent from the Grass - Users mailing list archive at Nabble.com.
