[GRASS-user] Problem in running r.basin
Priscilla_I isacco.silvia at gmail.com
Wed Oct 19 03:15:26 PDT 2016
Hi Micha,
thanks for you answer, as Margherita wrote "Silvia" is the directory in
which I'd like to save my results, and use r.stream only to check that
coordinates belongs to virtual stream network.
I followed Margherita advices but I already removed all old files and grass
kept in giving me error. So I thought it could be a problem related to the
fact that I was using GRASS downloaded with Qgis and there were some
warnings when I launched it.
I dowloaded GRASS 7.0.5 and tried to run r.basin with the NC sample dataset
as suggested in an old thread:
I follow the following procedure
- I create a new mapset in order to not have problems about old files and
overwriting
- I set the region
 * g.region -a raster=elevation at PERMANENT align=elevation at PERMANENT*
- I launch the command
 * r.basin map=elevation at PERMANENT prefix=b coordinates=637304,218585
dir=\tmp\test threshold=40*
it breaks with the error
*An ERROR occurred running r.basin*
*Please check for error messages above or try with another pairs of outlet
coordinates*
*Removing region definition <original>*
2016-10-18 19:04 GMT+02:00 margherita [via OSGeo.org] <
ml-node+s1560n5291321h58 at n6.nabble.com>:
> Micha,
> On Fri, Oct 14, 2016 at 11:14 PM, Micha Silver <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5291321&i=0>> wrote:
>> Hi,
>> Thanks for your answers, here the command line I run
>> r.basin map=Ghiandone_DEM at Silvia prefix=out
>> coordinates=368450.0,4954025.0
>> dir=Silvia threshold=1000 --overwrite
>> In your command line, is the raster map "Silvia" the flow direction
>> raster,
>> that was created from the DEM?
>> The dir parameter in r.basin is used to specify an external directory
> (folder) where to export the summary text file.
> Margherita Di Leo
> grass-user mailing list
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5291321&i=1>
> http://lists.osgeo.org/mailman/listinfo/grass-user
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Problem-in-running-
> r-basin-tp5290587p5291321.html
> To unsubscribe from Problem in running r.basin, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5290587&code=aXNhY2NvLnNpbHZpYUBnbWFpbC5jb218NTI5MDU4N3w3Mjk2MDM5MDE=>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-in-running-r-basin-tp5290587p5291413.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161019/6071d899/attachment.html>
