[GRASS-user] Problem in running r.basin
Silvia Isacco
isacco.silvia at gmail.com
Wed Oct 19 07:52:12 PDT 2016
I lost to install one of the dependencies r.stream.*
Now it run! Never take anything for granted.
It gives some warnings but I read they can be ignored
WARNING: Width for column x set to 255 (was not specified by OGR), some
strings may be truncated!
WARNING: Width for column Slope_ratio_Horton set to 255 (was not specified
by OGR), some strings may be truncated!
Last question: is it possible to save in an external file also the
percentiles of hypsometric/hypsographic curve?
2016-10-19 14:52 GMT+02:00 Priscilla_I <isacco.silvia at gmail.com>:
> Thanks for your patience Margherita,I tried with the manual example but i
> find the same error.
> *r.basin map=elevation prefix=my_basin coord=637304.924954,218617.100523
> dir=/tmp/bla threshold=1000*
> *SECTION 1 beginning: Initiating Variables. 4 sections total.*
> *SECTION 1a: Mark masked and NULL cells*
> *SECTION 1b: Determining Offmap Flow.*
> *SECTION 2: A* Search.*
> *SECTION 3a: Accumulating Surface Flow with MFD.*
> *SECTION 3b: Adjusting drainage directions.*
> *SEZIONE 4: Chiudendo Mappe.*
> *Closing accumulation map*
> *Writing out only positive flow accumulation values.*
> *Cells with a likely underestimate for flow accumulation can no longer be
> identified.*
> *Closing flow direction map*
> *Loading input raster maps...*
> *Initializing A* search...*
> *A* Search...*
> *Extracting streams...*
> *Thinning stream segments...*
> *Scrittura della mappa raster di output...*
> *Controllo dell'input per i tipi di colonna in corso...*
> *Number of columns: 3*
> *Number of rows: 1*
> *Importazione dei punti in corso ...*
> *Riempimento della tabella in corso...*
> *Si sta ricreando la topologia per il vettore
> <my_basin_elevation_outlet at Mapset6>...*
> *Registrando primitive...*
> *One primitive registered*
> *One vertex registered*
> *Costruendo aree...*
> *0 areas built*
> *0 isles built*
> *Isole allegate...*
> *Centroidi allegati...*
> *Numero di nodi: 0*
> *Numero di primitive: 1*
> *Numero di punti: 1*
> *Numero di linee: 0*
> *Numero di confini: 0*
> *Numero di centroidi: 0*
> *Numero di aree: 0*
> *Numero di isole: 0*
> *An ERROR occurred running r.basin*
> *Please check for error messages above or try with another pairs of outlet
> coordinates*
> *Removing region definition <original>*
> 2016-10-19 14:31 GMT+02:00 margherita [via OSGeo.org] <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5291470&i=0>>:
>> On Wed, Oct 19, 2016 at 12:15 PM, Priscilla_I <[hidden email]
>> <http:///user/SendEmail.jtp?type=node&node=5291456&i=0>> wrote:
>>> Hi Micha,
>>> thanks for you answer, as Margherita wrote "Silvia" is the directory in
>>> which I'd like to save my results, and use r.stream only to check that
>>> coordinates belongs to virtual stream network.
>>> I followed Margherita advices but I already removed all old files and
>>> grass kept in giving me error.
>> Yes, but it's a different error..
>>> So I thought it could be a problem related to the fact that I was using
>>> GRASS downloaded with Qgis and there were some warnings when I launched it.
>>> I dowloaded GRASS 7.0.5 and tried to run r.basin with the NC sample
>>> dataset as suggested in an old thread:
>>> I follow the following procedure
>>> - I create a new mapset in order to not have problems about old files
>>> and overwriting
>>> - I set the region
>>> * g.region -a raster=elevation at PERMANENT align=elevation at PERMANENT*
>>> - I launch the command
>>> * r.basin map=elevation at PERMANENT prefix=b coordinates=637304,218585
>>> dir=\tmp\test threshold=40*
>>> it breaks with the error
>>> outlet coordinates*
>> Can you try with the example in the manual?
>> https://grass.osgeo.org/grass70/manuals/addons/r.basin.html
>> g.region raster=elevation -p
>> r.basin map=elevation prefix=my_basin coord=637304.924954,218617.100523 \
>> dir=/tmp/test threshold=1000
>> Regards,
>> Margherita Di Leo
>> grass-user mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5291456&i=1>
>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/Problem-in-running-r-
>> basin-tp5290587p5291456.html
>> To unsubscribe from Problem in running r.basin, click here.
>> NAML
>> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: Problem in running r.basin
> <http://osgeo-org.1560.x6.nabble.com/Problem-in-running-r-basin-tp5290587p5291470.html>
> Sent from the Grass - Users mailing list archive
> <http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html> at
> Nabble.com.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161019/a3d5f649/attachment-0001.html>
