[GRASS-user] Problem in running r.basin
Micha Silver
Micha at arava.co.il
Wed Oct 19 13:07:40 PDT 2016
Priscilla_I wrote
> Hi Micha,
> thanks for you answer, as Margherita wrote "Silvia" is the directory in
> which I'd like to save my results, and use r.stream only to check that
> coordinates belongs to virtual stream network.
The "dir=" parameter is NOT a directory. It should be the flow direction
raster that you create in advance with either r.watershed, or
r.stream.extract.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-in-running-r-basin-tp5290587p5291563.html
Sent from the Grass - Users mailing list archive at Nabble.com.
