[GRASS-user] v.net.iso - segmentation fault error
Eduardo Corbelle Rico
eduardo.corbelle at gmx.net
Thu Oct 27 02:16:05 PDT 2016
O Mér, 26-10-2016 ás 23:18 +0200, Markus Metz escribiu:
> On Thu, Oct 13, 2016 at 9:55 AM, Eduardo Corbelle Rico
> <eduardo.corbelle at gmx.net> wrote:
> > Dear all,
> > I am unable to use v.net.iso because of a "segmentation fault"
> > error. I
> > have a script that used to work correctly in GRASS 6.4 (32 bit)
> > but
> > produces this error after I switched to GRASS 7.0.4 (64 bit).
> > If I try to follow both examples shown in https://grass.osgeo.org/g
> > rass
> > 70/manuals/v.net.iso.html (using the Spearfish dataset for GRASS 7)
> > the
> > same error appears:
> > > Building graph...
> > > Registering arcs...
> > > Segmentation fault
> The segmentation fault must happen in the vector libraries. I tested
> on Linux and can not reproduce the segmentation fault. Valgrind also
> does not show anything that could cause a segmentation fault. Can you
> provide a gdb backtrace?
> Markus M
Thank you Markus,
My system is debian Stretch, and the following lines describe my
attempt at generating a gdb backtrace. Please let me know if I should
do otherwise.
GRASS 7.0.5 (spearfish60_grass7):~ > gdb `which v.net.iso`
GNU gdb (Debian 7.11.1-2) 7.11.1
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl
.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show
copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /usr/lib/grass70/bin/v.net.iso...(no debugging
symbols found)...done.
(gdb) run input=myroads_net output=myroads_net_iso center_cats=1-100000
costs=1000,2000,5000
Starting program: /usr/lib/grass70/bin/v.net.iso input=myroads_net
output=myroads_net_iso center_cats=1-100000 costs=1000,2000,5000
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-
gnu/libthread_db.so.1".
Building graph...
Registering arcs...
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff6c64708 in tavl_probe ()
from /usr/lib/grass70/lib/libgrass_dgl.7.0.5.so
(gdb) bt full
#0 0x00007ffff6c64708 in tavl_probe ()
No symbol table info available.
#1 0x00007ffff6c65717 in dglTreeNodeAdd ()
#2 0x00007ffff6c5aa0c in dgl_add_edge_V1 ()
#3 0x00007ffff6c58a62 in dglAddEdge ()
#4 0x00007ffff7ba1d69 in Vect_net_build_graph ()
from /usr/lib/grass70/lib/libgrass_vector.7.0.5.so
#5 0x0000000000401aa9 in main ()
(gdb) l
1 ../sysdeps/x86_64/dl-procinfo.c: Non hai tal ficheiro ou
directorio.
> > What I am missing?
> > Thanks in advance.
> > Greetings.
> > Eduardo Corbelle
> > Dr. Eduardo Corbelle Rico
> > Land laboratory (LaboraTe)
> > Department of Agricultural and Forest Engineering
> > Universidade de Santiago de Compostela
> > e-mail: eduardo.corbelle at usc.es
> > Tel: +34 982 823 324
> > Fax: +34 982 285 926
> > Web: http://laborate.usc.es
> > http://masterterra.usc.es
> > http://github.com/eduardocorbelle
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
