[GRASS-user] i.segment.stats memory usage error
    James Duffy
    james.philip.duffy at gmail.com
    Thu Oct 27 08:45:47 PDT 2016
On 27 October 2016 at 16:33, Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> On 27/10/16 16:15, Moritz Lennert wrote:
>> On 27/10/16 15:38, James Duffy wrote:
>>> On 27 October 2016 at 13:53, Moritz Lennert
>>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
>>> wrote:
>>>     On 27/10/16 12:51, James Duffy wrote:
>>>         On 27 October 2016 at 11:45, Moritz Lennert
>>>         <mailto:mlennert at club.worldonline.be>>> wrote:
>>>             Le 27 octobre 2016 12:35:14 GMT+02:00, James Duffy
>>>             <james.philip.duffy at gmail.com
>>>         <mailto:james.philip.duffy at gmail.com>
>>>         <mailto:james.philip.duffy at gmail.com>>>
>>>             a écrit :
>>>             >On 27 October 2016 at 11:08, Moritz Lennert
>>>             >wrote:
>>>             >> Le 27 octobre 2016 11:22:02 GMT+02:00, James Duffy <
>>>         <mailto:james.philip.duffy at gmail.com>>> a écrit :
>>>             >> >Hello,
>>>             >> >I'm trying to use i.segment.stats with GRASS 7.0.4 in
>>>         the osgeolive
>>>             >> >32bit
>>>             >> >operating system.
>>>             >> >Prior to using this tool I have successfully created my
>>>         segmented
>>>             >map
>>>             >> >using
>>>             >> >i.segment.
>>>             >> >When I try to execute the following command:
>>>             >> >i.segment.stats --overwrite --verbose
>>>         map=gp_seg_optimum at gp1 \
>>> >rasters=gp_ortho.1 at gp1,gp_ortho.2 at gp1,gp_ortho.3 at gp1,gp_ortho.4 at gp1
>>>             >> >raster_statistics=min,max,mean,stddev,variance,sum \
>>> >csvfile=/home/jpd205/Wales_GRASS/GarronPill/gp_seg_stats \
>>>             >> >separator=comma
>>>             >> >I get this error:
>>>             >> >Calculating geometry statistics
>>>             >> >ERROR: G_malloc: unable to allocate 4273800320 bytes of
>>>         memory at
>>>             >> >       /tmp/tmpgzUtnA/r.object.geometry/main.c:129
>>>             >> This is coming from r.object.geometry.
>>>             >> What are your region settings (g.region -p) ? How many
>>>         segments do
>>>             >you
>>>             >> have ?
>>>             >GRASS 7.0.4 (GarronPill):~ > g.region -p
>>>             >projection: 99 (OSGB 1936 / British National Grid)
>>>             >zone:       0
>>>             >datum:      osgb36
>>>             >ellipsoid:  airy
>>>             >north:      208007.00931776
>>>             >south:      207952.59780698
>>>             >west:       200993.90853302
>>>             >east:       201097.28911076
>>>             >nsres:      0.00430914
>>>             >ewres:      0.00430914
>>>             >rows:       12627
>>>             >cols:       23991
>>>             >cells:      302934357
>>>             Are you sure 4mm is correct for the resolution ?
>>>         Yes. It's high resolution imagery from a drone.
>>>             What does r.info <http://r.info> <http://r.info> on
>>>             >> Try running I.segment.stats without requesting form
>>>         statistics.
>>>             >Running:
>>>             >separator=comma
>>>             Default is to do form statistics, so the above line also
>>> does. I
>>>             have to admit that I don't know what happens when you give
>>>         an empty
>>>             parameter such as
>>>             area_measures= or area_measures=""
>>>         gp_seg_optimum give you ?
>>>          | Map:      gp_seg_optimum                 Date: Thu Oct 27
>>>         06:45:57
>>>         2016    |
>>>          | Mapset:   gp1                            Login of Creator:
>>>         jpd205          |
>>>          | Location:
>>> GarronPill                                                       |
>>>          | DataBase:
>>> /home/jpd205/Wales_GRASS                                         |
>>>          | Title:     ( gp_seg_optimum
>>>          | Timestamp:
>>>         none                                                            |
>>>          |   Type of Map:  raster               Number of Categories:
>>>         0               |
>>>          |   Data Type:
>>>         CELL                                                       |
>>>          |   Rows:
>>>         12627                                                      |
>>>          |   Columns:
>>>         23991                                                      |
>>>          |   Total Cells:
>>>         302934357                                                  |
>>>          |        Projection: OSGB 1936 / British National
>>>         Grid                       |
>>>          |            N: 208007.00931776    S: 207952.59780698   Res:
>>>         0.00430914      |
>>>          |            E: 201097.28911076    W: 200993.90853302   Res:
>>>         0.00430914      |
>>>          |   Range of data:    min = 35  max =
>>>         133556294                              |
>>>     Ok, I think I see at least part of the problem: in GRASS 7.0
>>>     i.segment numbers segments non sequentially, i.e. whenever a new
>>>     segment is created out of the merger of two existing segments, a new
>>>     id is assigned. In GRASS trunk (the development version) i.segment
>>>     is rewritten to, at the end, number all segments sequentially from 1
>>>     to the number of segments.
>>>     r.object.geometry allocates memory according to the new system. As
>>>     it says in the code:
>>>         /* REMARK: The following is only true if object ids are
>>>     continuously numbered */
>>>         n_objects = max - min + 1;
>>>         obj_geos = G_malloc(n_objects * sizeof(struct obj_geo));
>>>     So, one solution would be to use the development version of GRASS.
>>>     Another would be to run r.clump on the result of the segmentation in
>>>     order to renumber the segments before running it through
>>>     i.segment.stats.
>>> This option seemed the most straightforward given my current setup. I
>>> ran r.clump with diagnoal enabled, and the output looked good. It only
>>> took 2mins to run.
>>> I then proceeded with the original i.segment.stats command and got the
>>> following:
>>> Calculating statistics for raster gp_ortho.1 at gp1
>>> ERROR: G_realloc: unable to allocate 572000 bytes of memory at
>>>        raster/r.univar/r.univar_main.c:324
>>> It looks like the tool got further, but is still getting stuck on
>>> something...
>> Yes, now there a memory issue in the part where it uses r.univar to
>> calculate statistics per segment on one of the spectral bands.
> Could you run
> r.univar -et gp_ortho.1 zones=ClumpedSegmentMap output=testoutput.csv
> to if r.univar by itself handles this (which would mean I could try to
> change the data handling in i.segment.stats to make it more memory
> efficient), or not ?
> Thanks !
> Moritz
r.info on the clumped map gives:
 | Map:      gp_seg_optimum_clump           Date: Thu Oct 27 14:28:30
2016    |
jpd205          |
GarronPill                                                       |
 | DataBase:
 | Title:    gp_seg_optimum_clump ( gp_seg_optimum_clump
 | Timestamp:
none                                                            |
0               |
 |   Data Type:
CELL                                                       |
 |   Rows:
12627                                                      |
 |   Columns:
23991                                                      |
 |   Total Cells:
302934357                                                  |
Grid                       |
0.00430914      |
0.00430914      |
 |   Range of data:    min = 1  max =
1264957                                 |
 |   Data
Source:                                                             |
 |   Data
Description:                                                        |
 |    generated by
r.clump                                                    |
Comments:        |
 |    r.clump --overwrite --verbose -d input="gp_seg_optimum at gp1"
output="\   |
 |    gp_seg_optimum_clump"
title="gp_seg_optimum_clump"                      |
Running:
r.univar -et gp_ortho.1 zones=gp_seg_optimum_clump output=testoutput2.csv
Returns:
Current region rows: 12627, cols: 23991
ERROR: G_realloc: unable to allocate 224000 bytes of memory at
James
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20161027/0f634987/attachment-0001.html>
