[GRASS-user] Vector file import formats
Randal Hale rjhale at northrivergeographic.com
Thu Oct 27 09:40:27 PDT 2016
The MXD files are just ArcGIS Map documents. They will hold no data -
only symbology.
You'll need to get your data out of the personal geodatabase files (the
.mdb files). It's been a while since I've tackled that - I wrote a
tutorial for doing this in QGIS. People have had hit or miss luck with
the tutorial -
http://www.northrivergeographic.com/qgis-accessing-personal-geodatabase.
It works for me (win 10 64 bit with QGIS).
Personal geodatabases were a first attempt at a database format for ESRI
when they left coverages. It's mostly been abandoned for the File Based
Geodatabase.
I know that probably isn't helping much - but - it might get you
started. I don't think there's a straight forward way to push that into
GRASS - there will need to be a few steps before hand.
Randy
On 10/27/2016 12:28 PM, Rich Shepard wrote:
>   I have a 90 files that are supposed to be figures but have the
> Microsoft
> Access .mdb extension and another 88 files with ARC/GIS .mxd extensions.
> When I look at supported formats for v.in.ogr I don't see either of those
> after sorting the list (why isn't it sorted anyway?).
>   Is there a way to import the vectors and associated (I presume) data
> into
> GRASS7x?
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Randal Hale
North River Geographic Systems, Inc
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale
