[GRASS-user] i.segment.stats memory usage error
Anna Petrášová kratochanna at gmail.com
Thu Oct 27 14:47:35 PDT 2016
On Thu, Oct 27, 2016 at 3:47 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> Le Thu, 27 Oct 2016 20:33:23 +0100,
> James Duffy <james.philip.duffy at gmail.com> a écrit :
>> On 27 October 2016 at 17:48, Moritz Lennert
>> > > Running:
>> > > r.univar -et gp_ortho.1 zones=gp_seg_optimum_clump
>> > > output=testoutput2.csv
>> > > Returns:
>> > > Current region rows: 12627, cols: 23991
>> > > ERROR: G_realloc: unable to allocate 224000 bytes of memory at
>> > >        raster/r.univar/r.univar_main.c:324
>> > Ok, so the issue is with r.univar (although the issue has made me
>> > aware that i.segment.stats could be made way more memory efficient
>> > as well).
>> > How much RAM do you have on your machine ?
>> It's a virtual machine which I have dedicated about 10GB.
>> > This warrants a bug report. Would you be willing to file one on
>> > http://trac.osgeo.org/grass ?
>> I'm happy to submit it if you can guide me as to what exactly should
>> go into it please?
> The bug report should concentrate on r.univar
> You should provide:
> - region settings (output of g.region -p)
> - info about the two maps going into the command, i.e. r.info, plus the
>   info that the segment map is an output of r.clump and thus
>   sequentially numbered
> - the error message
> I don't know how difficult it will be to allow for lower memory usage
> in r.univar, so we'll have to see if an improvement is possible.
I haven't read this thread carefully, so sorry if this is unrelated,
but I think the -e flag might require a lot of memory. Also, is this
64bit?
Anna
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
