[GRASS-user] Grass 7 and postgresql
Benoit ANDRE
benoit.andre at bcgeol.be
Fri Sep 2 03:51:11 PDT 2016
Moritz,
First, I move from 6 to 7 with /v.build/ or /v.build.all/ (depends on
locations)
Here, connections are already gone...
I connect with :
/db.connect driver=pg database="host=192.168.1.200,dbname=administration"/
/db.connect -p/ :
driver: pg
database: host=192.168.1.200,dbname=administration
schema: public
group:
/db.login --overwrite user=benoit/
ATTENTION: DB connection <pg/host=192.168.1.200,dbname=administration>
already exists and will be overwritten
When I try a /db.tables -p/, I get :
DBMI-PostgreSQL erreur de pilote :
Connection failed.
n'a pas pu se connecter au serveur : Aucun fichier ou dossier de ce type
Le serveur est-il actif localement et accepte-t-il les connexions
sur la
socket Unix « /var/run/postgresql/.s.PGSQL.5432 » ?
Connection failed.
sur la
ERREUR :Unable to open database <host=192.168.1.200,dbname=administration>
/v.db.connect/ (dialog box) isn't usable, because the field 'Name of
attribute table' is empty...
Il I try : /v.db.connect -o map=survey_bcg at benoit table=survey_bcg
key=cat layer=1/ (for facility, table name is the same as map name),
result is
Connection failed.
sur la
Connection failed.
sur la
ATTENTION: Impossible d'ouvrir la base de données
<host=192.168.1.200,dbname=administration> avec le driver <pg>
ERREUR :La table <survey_bcg7> n'existe pas dans la base de données
On my computer (192.168.1.11) : psql -V is psql (PostgreSQL) 9.2.8
The server (192.168.1.200) : psql -V is psql (PostgreSQL) 9.2.15
All the other programs using postresql, including grass 6.4.4 work fine
Thank you
Le 02/09/16 12:04, Moritz Lennert a écrit :
> On 02/09/16 11:38, Benoit ANDRE wrote:
>> Hi all,
>> Our GIS infrastructure is based on Grass 6.4.4, postrgresql 9.x and
>> Qgis. Those all together are perfectly working.
>> We want to update from 6.4.4 to 7.0.4. But we are confronted to a
>> problem with the database : connection to postgresql is no more possible
>> for all our maps (but still working with 6.4.4, and all the other soft
>> overlying on postgresql). The message is the 'normal' message wen the
>> connection is no possible (in french) :
>> /DBMI-PostgreSQL erreur de pilote ://
>> //Connection failed.//
>> //n'a pas pu se connecter au serveur : Aucun fichier ou dossier de ce
>> type//
>> // Le serveur est-il actif localement et accepte-t-il les connexions
>> sur la//
>> // socket Unix « /var/run/postgresql/.s.PGSQL.5432 » ?/
>> I really don't understand the problem.
>> Any idea ?
> We need a bit more information to be able to help you. What command
> leads to this error ? What did you do to move from grass6 to grass7 ?
> How is the data connection defined ('v.db.connect -p' and 'db.connect
> -p') ?
> Moritz
*Benoit André*
*Directeur - Gérant*
benoit.andre at bcgeol.be <mailto:benoit.andre at bcgeol.be>
Tel. | +32 475 61 84 94
skype | benoit_andre_bcg
Voir le profil de Benoit André sur LinkedIn
<https://be.linkedin.com/in/benoitandre>
*BCG SPRL*
Tél. | +32(0)81 58 26 11
Fax | +32(0)81 58 26 12
Chemin de la Foliette, 4 Bte 2
B-5000 - Namur
www.bcgeol.be <http://www.bcgeol.be> - plan d'accès
<https://maps.google.be/maps/ms?msid=210366068780572446312.0004dc0b834462107c00f&msa=0&ll=50.460427,4.856445&spn=0.001279,0.002411&iwloc=0004dc0b8345e35a35a20>
BCG LOGO <http://www.bcgeol.be>
Suivez-nous sur Lien Linkedin
<https://www.linkedin.com/company/bureau-conseil-en-g%C3%A9ologie-sprl>
Lien Facebook
<https://www.facebook.com/Bureau-Conseil-en-G%C3%A9ologie-153924548320189/?ref=hl>
Allons plus loin dans le respect de l'environnement : N'utilisons que
des produits sans empreinte écologiqueLogo Modere
<https://www.modere.eu/?referralCode=050281>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160902/4fa2ffde/attachment-0002.html>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160902/4fa2ffde/attachment-0003.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160902/4fa2ffde/attachment-0003.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160902/4fa2ffde/attachment-0004.gif>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160902/4fa2ffde/attachment-0002.png>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160902/4fa2ffde/attachment-0005.gif>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160902/4fa2ffde/attachment-0003.png>
