[GRASS-user] create location from CLI
Markus Neteler
neteler at osgeo.org
Tue Sep 6 13:37:48 PDT 2016
On Sep 6, 2016 9:25 PM, "Dave Roberts" <droberts at montana.edu> wrote:
> Hi Ken, Hi Sajid,
> Thanks for the pointers. I think my problem is that grass70 and
g.proj parse the files differently. I.e.,
> Here is file teste.prj
> PROJCS["Lambert_Conformal_Conic",
> GEOGCS["GCS_WGS_1984",
> DATUM["D_WGS_1984",
> SPHEROID["WGS_1984",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT["Degree",0.017453292519943295]],
> PROJECTION["Lambert_Conformal_Conic"],
> PARAMETER["standard_parallel_1",40],
> PARAMETER["standard_parallel_2",45],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-109],
> PARAMETER["false_easting",0],
> PARAMETER["false_northing",0],
> UNIT["Meter",1]]
> The following does not work
> grass70 -e -c teste.prj teste
> Creating new GRASS GIS location/mapset...
> ERROR: ERROR 4: `teste.prj' not recognised as a supported
> file format.
> ERROR: Could not read georeferenced file teste.prj using either OGR nor
> GDAL
Yes because it is not a raster or vector file.
> However, this does work
> grass70 -c teste
> g.proj -c wkt=teste.prj
This one is right.
> I'm having even worse luck with PROJ4 syntax of files.
AFAIK that's only supported in g.proj.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160906/390d1979/attachment-0001.html>
