[GRASS-user] create location from CLI
Dave Roberts
droberts at montana.edu
Tue Sep 6 20:41:30 PDT 2016
Paul,
On 09/06/16 16:28, Paul Kelly wrote:
> The proj4 parameter in g.proj takes a PROJ string description, not a
> file containing one.
> So,
> g.proj -c proj4="+proj=longlat +datum=WGS84"
> should work, as far as I can think.
Indeed it does, and that seems to be the end of the line. So it's
possible to create an arbitrary locations with nothing but projection
information (no data yet), but it takes two lines of code. That works
for me. When I migrate to 7.2 apparently I can do it in one.
Thanks all, Dave
