[GRASS-user] Problems using i.worldview.toar
Nikos Alexandris
nik at nikosalexandris.net
Fri Sep 9 00:37:56 PDT 2016
William Hudspeth:
>I am using i.worldview.toar with the latest version of GRASS 7.3. I was
>able to successfully download and install this extension. I have tried
>using the module with the following input and error. All of the input
>files exist, and I get an error stating that "No data base element files
>found". Help appreciated...
>i.worldview.toar band=worldview2_b1_RED at worldview2,worldview2_b2_GREEN at worldview2,worldview2_b3_BLUE at worldview2,worldview2_b4_NIR at worldview2 outputsuffix=toar utc=2010-04-11T18:07:06.558405Z doy=101 sea=60.3
Do you really need the 'worldview2' prefix for your band names? It's
identical to your Mapset's name. This is what a mapset is meant (or can
be used) for: a set of maps. In this case, it's a set of 'worldview2'
"maps".
Would you rename your bands and try again?
i.worldview.toar band=b1_RED,b2_GREEN,b3_BLUE,b4_NIR outputsuffix=toar utc=2010-04-11T18:07:06.558405Z doy=101 sea=60.3
Nikos
[rest deleted]
