[GRASS-user] Raster renamed but d.rast does not find it [RESOLVED]
    Rich Shepard
    rshepard at appl-ecosys.com
    Fri Sep  9 14:41:21 PDT 2016
On Fri, 9 Sep 2016, Rich Shepard wrote:
> Using the GUI I try to display bare_earth_2010 and the Layer Manager
> console window displays:
> Failed to run command 'd.rast map=hdr at topography'. Details:
   Rummaging around in the GUI tells me why the above error appears: the
'hdr' file that was renamed is still seen in the mapset and displays at the
top of the list. Using map properties I can select the correct name.
   Question: If a map is renamed why is the old name retained?
Rich
