[GRASS-user] Importing ESRI Grid file ... or Shapefile?
Helmut Kudrnovsky
hellik at web.de
Sat Sep 10 12:09:58 PDT 2016
Rich Shepard wrote
> The LiDAR data files do not have the same extent as the vector files, and
> they should. I think I incorrectly imported them.
> There are two flavors of the files: ESRI Grid and Shapefiles.
> I used the Grid files, specifying hdr.adf as the file to use. But,
> since
> the .prj file is specified when importing a shapefile I wonder if that's
> what I need with the Grid format. The metadata.xml has these bounds:
> <westbc Sync="TRUE">
> -123.253402
> </westbc>
> <eastbcSync="TRUE">-123.131197
> </eastbc>
> <northbcSync="TRUE">45.002688
> </northbc>
> <southbcSync="TRUE">44.925436
> </southbc>
> and
> <leftbc Sync="TRUE">
> 600316.500000
> </leftbc>
> <rightbcSync="TRUE">631069.500000
> </rightbc>
> <bottombcSync="TRUE">1169386.500000
> </bottombc>
> <topbc Sync="TRUE">
> 1196554.500000
> </topbc>
> Looks like both long/lat and Oregon State Plane coordinates are
> provided.
> The prj.adf file contains:
> Projection LAMBERT
> Datum HPGN
> Spheroid GRS80
> Units 3.280839895013123
> Zunits NO
> Xshift 0.0
> Yshift 0.0
> Parameters
> 43 0 0.0 /* 1st standard parallel
> 45 30 0.0 /* 2nd standard parallel
> -120 30 0.0 /* central meridian
> 41 45 0.0 /* latitude of projection's origin
> 400000.0 /* false easting (meters)
> 0.0 /* false northing (meters)
> The Shapefile for the area including my project has this projection:
> PROJCS["Lambert Conformal Conic", GEOGCS["GCS North American 1983
> HARN",DATUM["D North American 1983 HARN",SPHEROID["GRS
> 1980",6378137.0,298.257222101]],
> PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],
> PROJECTION["Lambert Conformal Conic"],
> PARAMETER["False Easting",1312335.958005249],
> PARAMETER["False Northing",0.0],
> PARAMETER["Central Meridian",-120.5],
> PARAMETER["Standard Parallel 1",43.0],
> PARAMETER["Standard Parallel 2",45.5],
> PARAMETER["Latitude Of Origin",41.75],
> UNIT["Foot",0.3048]]
> Should I put these source files in the WGS84-lat-long location, the
> Oregon-ll83 location, or the project location which is the Oregon State
> Plane projection? And, do I import the Grid or shapefile? I'm confused.
> TIA,
> Rich
> grass-user mailing list
> grass-user at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-user
It depends which data you need :
- Shape file: vector data
- Esri Grid: raster data
so these data may be/are different.
a common workflow I do with data in different projections:
- Defiine a projection in which you want to do your analysisi(1)s
- Reproject data in different projections than (1) either by
gdalwarp'ed/ogr2ogr or by v.proj/r.proj to this srs/projection
In this way data projection mixing can be avoided.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Importing-ESRI-Grid-file-or-Shapefile-tp5285121p5285124.html
Sent from the Grass - Users mailing list archive at Nabble.com.
