[GRASS-user] Import ASCII point file, project to current location
Vaclav Petras wenzeslaus at gmail.com
Sat Sep 10 13:26:50 PDT 2016
On Fri, Sep 9, 2016 at 6:24 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> -  g.proj -p /EPSG code/srs definition/proj4 string/...of the source
> location
> - g.proj -p / EPSG code/srs definition /proj4 string/...of the target
> location
> - sample input of v.in.ascii for the source location
> - used v.proj command
An alternative workflow for ASCII point data is using m.proj to reproject
the data before passing them to v.in.ascii:
https://grass.osgeo.org/grass72/manuals/m.proj.html
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160910/a44c0f95/attachment.html>
