[GRASS-user] Working with multiple mapsets in one location
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Tue Sep 13 09:53:13 PDT 2016
You can add other mapsets to the searchpath of your current mapset with g.mapsets
You can also address specific maps with their fully qualifieg name, like: mymap at mymapset
Cheers
Stefan
________________________________________
Von: grass-user [grass-user-bounces at lists.osgeo.org] im Auftrag von Rich Shepard [rshepard at appl-ecosys.com]
Gesendet: Dienstag, 13. September 2016 18:35
An: grass-user at lists.osgeo.org
Betreff: Re: [GRASS-user] Working with multiple mapsets in one location
On Tue, 13 Sep 2016, Blumentrath, Stefan wrote:
> I would use g.copy and g.remove. But you have to switch between the
> mapsets, first in target then in source. In grass 7.2 this might be
> possible in the data tab?
Stefan,
   Now that you write this, the solution seems vaguely familiar from way back
when.
   I prefer the CLI to GUIs whenever I have a choice, unless the GUI is much
more efficient.
   On my second question, if I'm working in one mapset is there a module that
allows me to work with maps from the current one and other mapsets?
Thanks very much,
Rich
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
