[GRASS-user] Importing data in .atx/.gdb format
Rich Shepard rshepard at appl-ecosys.com
Tue Sep 13 10:54:01 PDT 2016
On Tue, 13 Sep 2016, Even Rouault wrote:
> you can use v.in.ogr on the .gdb directory that contains the files you
> mention below. That will use underneath the OGR OpenFileGDB driver :
> http://gdal.org/drv_openfilegdb.html
Even,
   Thank you very much. If I knew how to add to the wiki import page I'd add
this information there.
Regards,
Rich
