[GRASS-user] r.mapcalc error
andry rustanto
arus_81 at yahoo.com
Tue Sep 13 12:53:17 PDT 2016
Hi Helmut,
the r.mapcalc error i found at the first time when i try to mosaic two images. Then I try r.mapcalc in another operation, for example :
r.mapcalc "image 1 = if( NDVI at 220215 >= 0.25 ,1 ,0)"
syntax error, unexpected INTEGER, expecting '('
Parse error
ERROR: parse error
regards,
Andry
On Tuesday, September 13, 2016 9:35 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
andry rustanto-2 wrote
> dear all,
> I got an error message when i try to mosaic images :
> Mosaicing 2 images...
> syntax error, unexpected INTEGER, expecting VARNAME or NAME
> Parse error
> ERROR: parse error
> ERROR: An error occurred while running r.mapcalc
> the syntax error is also appeared when i try to execute r.mapcalc, both
> using GUI and terminal. Seems the error occurred after i upgraded grass
> from 7.0.3 to 7.0.4. I hope someone can help, thank you in advance
> Andry
what is the used r.mapcalc command?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-mapcalc-error-tp5285649p5285653.html
Sent from the Grass - Users mailing list archive at Nabble.com.
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160913/63afecd1/attachment.html>
