[GRASS-user] Importing data in .atx/.gdb format
Rich Shepard rshepard at appl-ecosys.com
Wed Sep 14 05:43:31 PDT 2016
On Wed, 14 Sep 2016, Blumentrath, Stefan wrote:
> Regarding the v.in.ogr command, I was a bit unclear (with folder I meant
> the "FGDB object" whit the .gdb ending, which the OS treats a folder)
Stefan,
   Thanks for clarifying. I understood that 'folder' was Microsoft's name for
'directory.'
> For me:
> v.in.ogr -l input=D:\Geodatabases\Topographic_data_2014.gdb
> works without issues.
   Perhaps this is part of the problem: none of my files have a simple .gdb
extention:
a00000001.gdbindexes
a00000001.gdbtable
a00000001.gdbtablx
> As Helmut wrote, if that does not work you should check if your GDAL
> installation supports FGDB: ogrinfo --formats
   I'll read that web page again and see how gdal is built here. Since I have
the source I can easily rebuild it.
Thanks,
Rich
