[GRASS-user] Importing data in .atx/.gdb format [RESOLVED]
Helmut Kudrnovsky
hellik at web.de
Wed Sep 14 13:38:09 PDT 2016
Rich Shepard wrote
> On Wed, 14 Sep 2016, Even Rouault wrote:
>> Cool I've just updated the doc of the FileGDB and OpenFileGDB driver to
>> be
>> very clear on that :
>> """The OpenFileGDB driver provides read access to File Geodatabases
>> (.gdb directories) created by ArcGIS 9 and above. The dataset name must
>> be
>> the directory/folder name, and it must end with the .gdb extension."""
>> (will be refreshed online in a few hours)
> Even,
> That will help folks like me who are new to importing those data.
> I do need to move the source directory and re-import because the
> data are not long-lat coordinates and also not the projection of my
> project
> data. When grass finished importing it told me the map(s) could not be
> displayed because the north edge was undefined, and the source projection
> was not the target projection. Then the grass shell froze. Killing the
> process solved that.
IMHO it is a data provider issue.
Data without any information about srs (epsg code, projection, latlon or
whatever) should go back to the data Providers.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Importing-data-in-atx-gdb-format-tp5285623p5285954.html
Sent from the Grass - Users mailing list archive at Nabble.com.
