[GRASS-user] Deleted mapset; grass error on start
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Fri Sep 16 14:16:41 PDT 2016
Hei Rich,
If I am not mistaken, the last used mapset is stored in $HOME/.grass7/rc which is picked up by GRASS if you start it in text mode.
However, you can of course explicitly specify the mapset to use at startup using:
grass72 /mygrassdb/mylocation/mymapset -text
See also: https://grass.osgeo.org/grass72/manuals/grass7.html
Cheers
Stefan
-----Original Message-----
From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Rich Shepard
Sent: 16. september 2016 22:55
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] Deleted mapset; grass error on start
I deleted a mapset in one location and now when I invoke grass7x it shows an error because the mapset is not found. Does something need to be cleaned up by hand?
TIA,
Rich
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
