[GRASS-user] A question about raster map resolutions
Helmut Kudrnovsky
hellik at web.de
Tue Sep 20 23:52:39 PDT 2016
Rich Shepard wrote
> The LiDAR source location has x- and y-resolution of 3 feet
> (international) and several thousand cells east-west and north-south.
> g.region -p for this location displays:
> projection: 99 (unnamed)
> zone: 0
> datum: ** unknown (default: WGS84) **
> ellipsoid: grs80
> north: 1286590.24500872
> south: 1240510.24500872
> west: 634966.76150938
> east: 664972.76150938
> nsres: 3
> ewres: 3
> rows: 15360
> cols: 10002
> cells: 153630720
> When in the project location g.region -p produces:
> projection: 99 (NAD_1983_HARN_StatePlane_Oregon_North_FIPS_3601_Feet_Intl)
> zone: 0
> datum: nad83harn
> ellipsoid: grs80
> north: 588219.90693215
> south: 536993.58817534
> west: 7524575.13218961
> east: 7561596.20977101
> nsres: 2561.31593784
> ewres: 1851.05387907
> rows: 20
> cols: 20
> cells: 400
> I want to understand why the nsres is now 2561+ feet, the ewres now
> 1851+
> feet, and the numbers of rows and columns has decreased so drastically.
> Looking forward to learning,
> Rich
> grass-user mailing list
> grass-user at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-user
If it is about raster reprojection, there are hints in the r.proj manual
about region settings before applying r.proj.
E.g.
A simple way to do this is to check the projected bounds of the input map in
the current location's projection using the -p flag. The -g flag reports the
same thing, but in a form which can be directly cut and pasted into a
g.region command. After setting the region in that way you might check the
cell resolution with "g.region -p" then snap it to a regular grid with
g.region's -a flag. E.g. g.region -a res=5 -p. Note that this is just a
rough guide.
A more involved, but more accurate, way to do this is to generate a vector
"box" map of the region in the source location using v.in.region -d. This
"box" map is then reprojected into the target location with v.proj. Next the
region in the target location is set to the extent of the new vector map
with g.region along with the desired raster resolution (g.region -m can be
used in Latitude/Longitude locations to measure the geodetic length of a
pixel). r.proj is then run for the raster map the user wants to reproject.
In this case a little preparation goes a long way.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/A-question-about-raster-map-resolutions-tp5286992p5287020.html
Sent from the Grass - Users mailing list archive at Nabble.com.
