[GRASS-user] Unintended consequences [UPDATE 2]
Rich Shepard
rshepard at appl-ecosys.com
Thu Sep 29 16:10:38 PDT 2016
On Wed, 28 Sep 2016, Rich Shepard wrote:
> This happens only when the GUI is used to re-project a file. Running on
> the command line does not grab the mouse/trackball buffer.
Additional issue due to wxPython overhead: re-projecting a vector map with
v.proj using the GUI failed after 92 minutes with an out-of-memory error.
running the same module from the command line does not have this issue; it's
been running now for 110 minutes and approaching 5x10^6 registered
primitives.
Rich
