[GRASS-user] Fail to configure grass-7.0.4 under Ubuntu 16.04.1
Anna Petrášová
kratochanna at gmail.com
Thu Sep 29 17:51:57 PDT 2016
On Thu, Sep 29, 2016 at 8:35 PM, JIA Pei <jp4work at gmail.com> wrote:
> Thanks Anna:
> Now, I got the following error.log :
> Any further suggestions????
do what it suggests:
"In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library."
and post the errors here. Anything special about your system
configuration? I was just compiling GRASS on Ubuntu 16.04 without
problems.
Anna
>> GRASS GIS 7.3.svn r69608 compilation log
>> Started compilation: Thu Sep 29 17:30:12 PDT 2016
>> Errors in:
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/pngdriver
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/psdriver
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/htmldriver
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/cairodriver
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/db/sqlp
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/vector
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/imagery
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/cluster
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/rst/interp_float
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/lidar
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/raster3d/test
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/init
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/ogsf
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/nviz
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/exceptions
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/script
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/ctypes
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/temporal
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/pygrass
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/pydispatch
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/imaging
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/gunittest
>> ......//rsgis/OSGeo/grass/grass7_trunk/lib/manage
>> ......//rsgis/OSGeo/grass/grass7_trunk/db
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.fontlist
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.erase
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.colorlist
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.geodesic
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.colortable
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.graph
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.barscale
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.info
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.his
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.labels
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.path
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.histogram
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.legend.vect
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.linegraph
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.grid
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.profile
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.rast
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.northarrow
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.rgb
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.rast.arrow
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.rast.num
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.vect
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.vect.chart
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.vect.thematic
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.mon
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.rhumbline
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.text
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.title
>> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.where
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.findfile
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.copy
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.list
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.findetc
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.dirseps
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.gui
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.gisenv
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.filename
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.cairocomp
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.access
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.mapset
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.message
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.region
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.remove
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.pnmcomp
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.mapsets
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.rename
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.ppmtopng
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.parser
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.tempfile
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.version
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/manage/lister
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.mkfontcap
>> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.proj
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.in.lidar
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.in.ascii
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.in.bin
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.cross.rast
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.gradient
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.gwflow
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.info
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.in.v5d
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.mask
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.null
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.flow
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.out.ascii
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.neighbors
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.out.bin
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.mkdspf
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.retile
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.stats
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.support
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.timestamp
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.out.vtk
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.out.netcdf
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.to.rast
>> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.out.v5d
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.build
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.class
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.buffer
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.build.polylines
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.category
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.colors
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.clean
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.cluster
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.colors.out
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.db.connect
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.db.select
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.distance
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.drape
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.delaunay
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.decimate
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.extract
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.extrude
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.edit
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.generalize
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.hull
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.info
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.ascii
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.db
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.dxf
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.label
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.lidar.correction
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.lidar.edgedetection
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.kcv
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.kernel
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.lidar.growing
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.proj
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.mkgrid
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.alloc
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.neighbors
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.centrality
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.allpairs
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.bridge
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.connectivity
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.components
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.distance
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.flow
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.path
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.salesman
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.iso
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.spanningtree
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.normal
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.steiner
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.visibility
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.ascii
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.timetable
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.dxf
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.lidar
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.vtk
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.svg
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.pov
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.overlay
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.outlier
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.perturb
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.parallel
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.patch
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.split
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.qcount
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.random
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.reclass
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.sample
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.rectify
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.support
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.select
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.surf.bspline
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.surf.rst
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.lrs
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.surf.idw
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.region
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.to.db
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.to.rast
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.to.3d
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.to.rast3
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.type
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.univar
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.voronoi
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.what
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.what.rast
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.what.rast3
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.vect.stats
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.vol.rst
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.ogr
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.ogr
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.external
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.lidar
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.transform
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.segment
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.timestamp
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.to.points
>> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.external.out
>> ......//rsgis/OSGeo/grass/grass7_trunk/misc/m.transform
>> ......//rsgis/OSGeo/grass/grass7_trunk/misc/m.nviz.image
>> ......//rsgis/OSGeo/grass/grass7_trunk/misc/m.measure
>> ......//rsgis/OSGeo/grass/grass7_trunk/misc/m.cogo
>> ......//rsgis/OSGeo/grass/grass7_trunk/misc/m.nviz.script
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.cca
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.cluster
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.eb.eta
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.biomass
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.eb.evapfr
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.aster.toar
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.albedo
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.eb.hsebal01
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.eb.netrad
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.eb.soilheatflux
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.gensig
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.evapo.time
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.evapo.pm
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.gensigset
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.group
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.evapo.mh
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.evapo.pt
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.emissivity
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.maxlik
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.rectify
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.his.rgb
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.segment
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.smap
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.target
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.landsat.acca
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.rgb.his
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.pca
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.landsat.toar
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.topo.corr
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.fft
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.ifft
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.zc
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.ortho.photo/lib
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.ortho.photo/i.ortho.camera
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.ortho.photo/i.ortho.elev
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.ortho.photo/i.ortho.rectify
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.vi
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.atcorr
>> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.modis.qc
>> ......//rsgis/OSGeo/grass/grass7_trunk/ps/ps.map
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.correlate
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.redraw
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.rast.edit
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.to.rast
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.rast.leg
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.out.file
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.frame
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.polar
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.shade
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.in.ogr
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.what.vect
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.what.rast
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.droptable
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.dropcolumn
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.test
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.out.ogr
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.univar
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/g.extension.all
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/g.search.modules
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.colors.enhance
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/g.manual
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.in.spotvgt
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.image.mosaic
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.oif
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.spectral
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/m.proj
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.tasscap
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.colors.stddev
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.buffer.lowmem
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.blend
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.pansharpen
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.in.wms
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.fillnulls
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.import
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.grow
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.in.srtm
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.in.aster
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.mask
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.out.xyz
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.pack
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.reclass.area
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.plane
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.shade
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.rgb
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.unpack
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.tileset
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r3.in.xyz
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.addcolumn
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.join
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.centroids
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.build.all
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.dropcolumn
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.addtable
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.droprow
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.droptable
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.univar
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.renamecolumn
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.reconnect.all
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.import
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.update
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.in.e00
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.in.geonames
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.dissolve
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.in.mapgen
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.in.lines
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.report
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.pack
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.rast.stats
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.what.strds
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.to.lines
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.unpack
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.in.wfs
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.what.vect
>> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/wxpyimgview
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.connect
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.remove
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.create
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.list
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.topology
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.merge
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.support
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.info
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.accdetect
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.accumulate
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.aggregate
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.unregister
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.register
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.sample
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.aggregate.ds
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.colors
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.contour
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.mapcalc
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.list
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.to.rast3
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.univar
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.neighbors
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.series
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.algebra
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.export
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.gapfill
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.out.vtk
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.extract
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.to.vect
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.what
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.import
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast3d.list
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast3d.extract
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast3d.mapcalc
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rename
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast3d.algebra
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast3d.univar
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.snap
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.shift
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.select
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.list
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.export
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.db.select
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.algebra
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.import
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.what.strds
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.extract
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.observe.strds
>> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.univar
>> ......//rsgis/OSGeo/grass/grass7_trunk/doc
>> ......//rsgis/OSGeo/grass/grass7_trunk/gui/wxpython
>> ......//rsgis/OSGeo/grass/grass7_trunk/visualization/ximgview
>> ......//rsgis/OSGeo/grass/grass7_trunk/locale
>> ......//rsgis/OSGeo/grass/grass7_trunk/man
>> 'make'.
>> Finished compilation: Thu Sep 29 17:31:30 PDT 2016
> cheers
> On Wed, Sep 28, 2016 at 4:56 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Wed, Sep 28, 2016 at 7:41 PM, JIA Pei <jp4work at gmail.com> wrote:
>> > My working Environment: Ubuntu 16.04.1 + GCC/G++ 5.4.0
>> > I now moves to grass 7.3 SVN, which seems to be the right version I
>> > should
>> > go for????
>> > It seems I can do the following configuration directly...
>> > It seems OpenDWG has already been replaced by LibreDWG ??? Any plan to
>> > have
>> > OpenDWG upgraded to LibreDWG???
>> > CFLAGS="-O2 -Wall -fPIC" CXXFLAGS="-O2 -Wall -fPIC" LDFLAGS="-s"
>> > ./configure \
>> > --enable-largefile=yes \
>> > --with-blas=yes --with-blas-includes=/usr/include
>> > --with-blas-libs=/usr/lib/libblas/ \
>> > --with-lapack=yes --with-lapack-includes=
>> > --with-lapack-libs=/usr/lib/lapack \
>> > --with-netcdf= \
>> > --with-readline=yes --with-readline-includes=/usr/include/readline
>> > --with-readline-libs=/usr/lib/x86_64-linux-gnu \
>> > --with-openmp=yes --with-openmp-includes=/usr/lib/openmpi/include
>> > --with-openmp-libs=/usr/lib/openmpi/lib \
>> > --with-pthread=yes --with-pthread-includes= --with-pthread-libs= \
>> > --with-liblas=/usr/local/bin/liblas-config \
>> > --with-libredwg=yes --with-libredwg-includes=/usr/local/include
>> > --with-libredwg-libs=/usr/local/lib \
>> > --with-nls \
>> > --with-cxx \
>> > --with-proj-share=/usr/share/proj/ \
>> > --with-geos \
>> > --with-wxwidgets \
>> > --with-cairo \
>> > --with-opengl-libs=/usr/include/GL \
>> > --with-freetype=yes
>> > --with-freetype-includes="/usr/include/freetype2/" \
>> > --with-postgres=no \
>> > --with-sqlite=yes \
>> > --with-mysql=yes --with-mysql-includes="/usr/include/mysql" \
>> > --with-odbc=no \
>> > --with-bzlib=yes --with-bzlib-includes=/usr/include
>> > --with-bzlib-libs=/usr/lib/x86_64-linux-gnu \
>> > --with-opencl=yes --with-opencl-includes=/usr/local/cuda/include
>> > --with-opencl-libs=/usr/local/cuda/lib64 \
>> > 2>&1 | tee config_log.txt
>> > GRASS is now configured for: x86_64-pc-linux-gnu
>> > Source directory:
>> > /home/jiapei/Downloads/rsgis/OSGeo/grass/grass-7.3
>> > Build directory:
>> > Installation directory: ${prefix}/grass-7.3.svn
>> > Startup script in directory:${exec_prefix}/bin
>> > C compiler: gcc -O2 -Wall -fPIC
>> > C++ compiler: c++ -O2 -Wall -fPIC
>> > Building shared libraries: yes
>> > OpenGL platform: X11
>> > MacOSX application: no
>> > MacOSX architectures:
>> > MacOSX SDK:
>> > BLAS support: yes
>> > BZIP2 support: yes
>> > C++ support: yes
>> > Cairo support: yes
>> > DWG support: no
>> > FFTW support: yes
>> > FreeType support: yes
>> > GDAL support: yes
>> > GEOS support: yes
>> > LAPACK support: yes
>> > Large File support (LFS): yes
>> > libLAS support: yes
>> > MySQL support: yes
>> > NetCDF support: yes
>> > NLS support: yes
>> > ODBC support: no
>> > OGR support: yes
>> > OpenCL support: yes
>> > OpenGL support: yes
>> > OpenMP support: yes
>> > PDAL support: no
>> > PNG support: yes
>> > POSIX thread support: yes
>> > PostgreSQL support: no
>> > Readline support: yes
>> > Regex support: yes
>> > SQLite support: yes
>> > TIFF support: yes
>> > X11 support: yes
>> > However, it fails to build...
>> > GISBASE="....../grass/grass-7.3/dist.x86_64-pc-linux-gnu"
>> > ARCH="x86_64-pc-linux-gnu"
>> > ARCH_DISTDIR="....../grass/grass-7.3/dist.x86_64-pc-linux-gnu"
>> > VERSION_NUMBER=7.3.svn VERSION_DATE=2016 python ./build_full_index.py
>> > File "./build_full_index.py", line 35
>> > classes.append((prefix, class_labels.get(prefix, prefix)))
>> > TabError: inconsistent use of tabs and spaces in indentation
>> Please try again, I just fixed it.
>> Anna
>> > Makefile:105: recipe for target
>> > '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/docs/html/full_index.html'
>> > failed
>> > make[3]: ***
>> > [....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/docs/html/full_index.html]
>> > Error 1
>> > make[3]: Leaving directory '....../grass/grass-7.3/man'
>> > Makefile:43: recipe for target 'default' failed
>> > make[2]: *** [default] Error 2
>> > make[2]: Leaving directory '....../grass/grass-7.3/man'
>> > make[2]: Entering directory '....../grass/grass-7.3/macosx'
>> > make[2]: Leaving directory '....../grass/grass-7.3/macosx'
>> > make[2]: Entering directory '....../grass/grass-7.3/mswindows'
>> > make[2]: Nothing to be done for 'first'.
>> > make[2]: Leaving directory '....../grass/grass-7.3/mswindows'
>> > make[1]: Leaving directory '....../grass/grass-7.3'
>> > make ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/AUTHORS
>> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/CHANGES
>> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/CITING
>> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/COPYING
>> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/GPL.TXT
>> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/INSTALL
>> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/REQUIREMENTS.html
>> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/contributors.csv
>> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/contributors_extra.csv
>> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/translators.csv
>> > make[1]: Entering directory '....../grass/grass-7.3'
>> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/AUTHORS' is up
>> > to
>> > date.
>> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/CHANGES' is up
>> > to
>> > date.
>> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/CITING' is up
>> > to
>> > date.
>> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/COPYING' is up
>> > to
>> > date.
>> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/GPL.TXT' is up
>> > to
>> > date.
>> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/INSTALL' is up
>> > to
>> > date.
>> > make[1]:
>> > '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/REQUIREMENTS.html'
>> > is up to date.
>> > make[1]:
>> > '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/contributors.csv'
>> > is up to date.
>> > make[1]:
>> > '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/contributors_extra.csv'
>> > is
>> > up to date.
>> > make[1]:
>> > '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/translators.csv'
>> > is up to date.
>> > make manifests
>> > make[1]: Nothing to be done for 'manifests'.
>> > GRASS GIS 7.3.svn r69562M compilation log
>> > Started compilation: Wed Sep 28 16:37:18 PDT 2016
>> > Errors in:
>> > ....../grass/grass-7.3/lib/pngdriver
>> > ....../grass/grass-7.3/lib/psdriver
>> > ....../grass/grass-7.3/lib/htmldriver
>> > ....../grass/grass-7.3/lib/cairodriver
>> > ....../grass/grass-7.3/lib/db/sqlp
>> > ....../grass/grass-7.3/lib/vector
>> > ....../grass/grass-7.3/lib/imagery
>> > ....../grass/grass-7.3/lib/cluster
>> > ....../grass/grass-7.3/lib/rst/interp_float
>> > ....../grass/grass-7.3/lib/lidar
>> > ....../grass/grass-7.3/lib/raster3d/test
>> > ....../grass/grass-7.3/lib/ogsf
>> > ....../grass/grass-7.3/lib/nviz
>> > ....../grass/grass-7.3/lib/python/exceptions
>> > ....../grass/grass-7.3/lib/python/script
>> > ....../grass/grass-7.3/lib/python/ctypes
>> > ....../grass/grass-7.3/lib/python/temporal
>> > ....../grass/grass-7.3/lib/python/pygrass
>> > ....../grass/grass-7.3/lib/python/pydispatch
>> > ....../grass/grass-7.3/lib/python/imaging
>> > ....../grass/grass-7.3/lib/python/gunittest
>> > ....../grass/grass-7.3/lib/manage
>> > ....../grass/grass-7.3/db
>> > ....../grass/grass-7.3/display
>> > ....../grass/grass-7.3/general/g.access
>> > ....../grass/grass-7.3/general/g.cairocomp
>> > ....../grass/grass-7.3/general/g.copy
>> > ....../grass/grass-7.3/general/g.dirseps
>> > ....../grass/grass-7.3/general/g.filename
>> > ....../grass/grass-7.3/general/g.findetc
>> > ....../grass/grass-7.3/general/g.findfile
>> > ....../grass/grass-7.3/general/g.gisenv
>> > ....../grass/grass-7.3/general/g.gui
>> > ....../grass/grass-7.3/general/g.list
>> > ....../grass/grass-7.3/general/g.mapset
>> > ....../grass/grass-7.3/general/g.mapsets
>> > ....../grass/grass-7.3/general/g.message
>> > ....../grass/grass-7.3/general/g.mkfontcap
>> > ....../grass/grass-7.3/general/g.parser
>> > ....../grass/grass-7.3/general/g.pnmcomp
>> > ....../grass/grass-7.3/general/g.ppmtopng
>> > ....../grass/grass-7.3/general/g.proj
>> > ....../grass/grass-7.3/general/g.region
>> > ....../grass/grass-7.3/general/g.remove
>> > ....../grass/grass-7.3/general/g.rename
>> > ....../grass/grass-7.3/general/g.tempfile
>> > ....../grass/grass-7.3/general/g.version
>> > ....../grass/grass-7.3/general/manage/lister
>> > ....../grass/grass-7.3/raster
>> > ....../grass/grass-7.3/raster3d
>> > ....../grass/grass-7.3/vector
>> > ....../grass/grass-7.3/misc/m.cogo
>> > ....../grass/grass-7.3/misc/m.measure
>> > ....../grass/grass-7.3/misc/m.nviz.image
>> > ....../grass/grass-7.3/misc/m.nviz.script
>> > ....../grass/grass-7.3/misc/m.transform
>> > ....../grass/grass-7.3/imagery
>> > ....../grass/grass-7.3/ps/ps.map
>> > ....../grass/grass-7.3/scripts/d.correlate
>> > ....../grass/grass-7.3/scripts/d.frame
>> > ....../grass/grass-7.3/scripts/d.out.file
>> > ....../grass/grass-7.3/scripts/d.to.rast
>> > ....../grass/grass-7.3/scripts/d.polar
>> > ....../grass/grass-7.3/scripts/d.rast.edit
>> > ....../grass/grass-7.3/scripts/d.rast.leg
>> > ....../grass/grass-7.3/scripts/d.redraw
>> > ....../grass/grass-7.3/scripts/d.shade
>> > ....../grass/grass-7.3/scripts/d.what.rast
>> > ....../grass/grass-7.3/scripts/d.what.vect
>> > ....../grass/grass-7.3/scripts/db.dropcolumn
>> > ....../grass/grass-7.3/scripts/db.droptable
>> > ....../grass/grass-7.3/scripts/db.in.ogr
>> > ....../grass/grass-7.3/scripts/db.out.ogr
>> > ....../grass/grass-7.3/scripts/db.test
>> > ....../grass/grass-7.3/scripts/db.univar
>> > ....../grass/grass-7.3/scripts/g.extension
>> > ....../grass/grass-7.3/scripts/g.extension.all
>> > ....../grass/grass-7.3/scripts/g.manual
>> > ....../grass/grass-7.3/scripts/g.search.modules
>> > ....../grass/grass-7.3/scripts/i.colors.enhance
>> > ....../grass/grass-7.3/scripts/i.image.mosaic
>> > ....../grass/grass-7.3/scripts/i.in.spotvgt
>> > ....../grass/grass-7.3/scripts/i.oif
>> > ....../grass/grass-7.3/scripts/i.pansharpen
>> > ....../grass/grass-7.3/scripts/i.spectral
>> > ....../grass/grass-7.3/scripts/i.tasscap
>> > ....../grass/grass-7.3/scripts/m.proj
>> > ....../grass/grass-7.3/scripts/r.blend
>> > ....../grass/grass-7.3/scripts/r.buffer.lowmem
>> > ....../grass/grass-7.3/scripts/r.colors.stddev
>> > ....../grass/grass-7.3/scripts/r.fillnulls
>> > ....../grass/grass-7.3/scripts/r.grow
>> > ....../grass/grass-7.3/scripts/r.import
>> > ....../grass/grass-7.3/scripts/r.in.aster
>> > ....../grass/grass-7.3/scripts/r.in.srtm
>> > ....../grass/grass-7.3/scripts/r.in.wms
>> > ....../grass/grass-7.3/scripts/r.mask
>> > ....../grass/grass-7.3/scripts/r.out.xyz
>> > ....../grass/grass-7.3/scripts/r.pack
>> > ....../grass/grass-7.3/scripts/r.plane
>> > ....../grass/grass-7.3/scripts/r.reclass.area
>> > ....../grass/grass-7.3/scripts/r.rgb
>> > ....../grass/grass-7.3/scripts/r.shade
>> > ....../grass/grass-7.3/scripts/r.tileset
>> > ....../grass/grass-7.3/scripts/r.unpack
>> > ....../grass/grass-7.3/scripts/r3.in.xyz
>> > ....../grass/grass-7.3/scripts/v.build.all
>> > ....../grass/grass-7.3/scripts/v.centroids
>> > ....../grass/grass-7.3/scripts/v.db.addcolumn
>> > ....../grass/grass-7.3/scripts/v.db.addtable
>> > ....../grass/grass-7.3/scripts/v.db.join
>> > ....../grass/grass-7.3/scripts/v.db.dropcolumn
>> > ....../grass/grass-7.3/scripts/v.db.droprow
>> > ....../grass/grass-7.3/scripts/v.db.droptable
>> > ....../grass/grass-7.3/scripts/v.db.renamecolumn
>> > ....../grass/grass-7.3/scripts/v.db.reconnect.all
>> > ....../grass/grass-7.3/scripts/v.db.univar
>> > ....../grass/grass-7.3/scripts/v.db.update
>> > ....../grass/grass-7.3/scripts/v.dissolve
>> > ....../grass/grass-7.3/scripts/v.import
>> > ....../grass/grass-7.3/scripts/v.in.e00
>> > ....../grass/grass-7.3/scripts/v.in.geonames
>> > ....../grass/grass-7.3/scripts/v.in.lines
>> > ....../grass/grass-7.3/scripts/v.in.mapgen
>> > ....../grass/grass-7.3/scripts/v.in.wfs
>> > ....../grass/grass-7.3/scripts/v.rast.stats
>> > ....../grass/grass-7.3/scripts/v.report
>> > ....../grass/grass-7.3/scripts/v.pack
>> > ....../grass/grass-7.3/scripts/v.to.lines
>> > ....../grass/grass-7.3/scripts/v.unpack
>> > ....../grass/grass-7.3/scripts/v.what.strds
>> > ....../grass/grass-7.3/scripts/v.what.vect
>> > ....../grass/grass-7.3/scripts/wxpyimgview
>> > ....../grass/grass-7.3/temporal
>> > ....../grass/grass-7.3/gui/wxpython
>> > ....../grass/grass-7.3/visualization/ximgview
>> > ....../grass/grass-7.3/locale
>> > 'make'.
>> > will
>> > Finished compilation: Wed Sep 28 16:37:31 PDT 2016
>> > Makefile:57: recipe for target 'default' failed
>> > make: *** [default] Error 1
>> > jiapei:grass-7.3$
>> > On Wed, Sep 28, 2016 at 4:56 AM, Thomas Adams <tea3rd at gmail.com> wrote:
>> >> You can compile with hdf5... not a problem; same with python3, I
>> >> believe
>> >> Tom
>> >> On Wed, Sep 28, 2016 at 7:05 AM, JIA Pei <jp4work at gmail.com> wrote:
>> >>> By this command " sudo apt-get build-dep grass", I got:
>> >>>> The following NEW packages will be installed:
>> >>>> autoconf2.13 libgdal-dev libgdal1i libhdf4-0-alt libhdf4-alt-dev
>> >>>> liblas-c-dev liblas-c3 liblas-dev liblas3 netcdf-bin python-pil
>> >>>> python-ply
>> >>>> python-wxgtk3.0 python-wxversion
>> >>> But, unfortunately,
>> >>> 1) installed my own libgdal-dev, instead of Ubuntu's default one from
>> >>> repository
>> >>> 2) I NEVER use libhdf4, clearly I prefer libhdf5
>> >>> 3) I use Python 3.5.2, instead of python 2
>> >>> 4) liblas from repository requires libgdal-dev from repository, and
>> >>> relies on libhdf4 ....
>> >>> So, will grass move to
>> >>> Python3
>> >>> libhdf5
>> >>> Cheers
>> >>> On Tue, Sep 27, 2016 at 6:41 PM, Thomas Adams <tea3rd at gmail.com>
>> >>> wrote:
>> >>>> Go here: https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
>> >>>> Look at this:
>> >>>> tar xzf grass-7.0.4.tar.gz
>> >>>> cd grass-7.0.4/
>> >>>> # install build dependency packages:
>> >>>> # configure to taste..
>> >>>> CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
>> >>>> --with-nls \
>> >>>> --with-cxx \
>> >>>> --with-geos \
>> >>>> --with-wxwidgets \
>> >>>> --with-cairo \
>> >>>> --with-freetype=yes
>> >>>> --with-postgres=yes
>> >>>> --with-postgres-includes="/usr/include/postgresql" \
>> >>>> --with-sqlite=yes \
>> >>>> --with-odbc=no \
>> >>>> # build using 4 CPU cores
>> >>>> time make -j 4 2>&1 | tee build_log.txt
>> >>>> sudo make install
>> >>>> Tom
>> >>>> On Tue, Sep 27, 2016 at 8:34 PM, JIA Pei <jp4work at gmail.com> wrote:
>> >>>>> Hi, all:
>> >>>>> I failed to configure grass-7.0.4, can anybody give me a hand?
>> >>>>> OS: Ubuntu 16.04.1
>> >>>>> GCC/G++: Ubuntu 5.4.0-6ubuntu1~16.04.2
>> >>>>> FreeType: libfreetype6 2.6.1-0.1ubuntu2
>> >>>>>> jiapei:grass-7.0.4$ ./configure
>> >>>>>> checking host system type... x86_64-pc-linux-gnu
>> >>>>>> checking for gcc... gcc
>> >>>>>> checking whether the C compiler (gcc ) works... yes
>> >>>>>> checking whether the C compiler (gcc ) is a cross-compiler... no
>> >>>>>> checking whether we are using GNU C... yes
>> >>>>>> checking whether gcc accepts -g... yes
>> >>>>>> checking for Cygwin environment... no
>> >>>>>> checking for mingw32 environment... no
>> >>>>>> checking for executable suffix... no
>> >>>>>> checking for full floating-point support... yes
>> >>>>>> checking for pwd... /bin/pwd
>> >>>>>> checking for source directory...
>> >>>>>> /home/jiapei/Downloads/rsgis/OSGeo/grass/grass-7.0.4
>> >>>>>> checking for build directory...
>> >>>>>> checking for svnversion... /usr/bin/svnversion
>> >>>>>> checking for MacOSX App... no
>> >>>>>> checking for MacOSX architectures... no
>> >>>>>> checking for MacOSX SDK... no
>> >>>>>> checking how to build libraries... shared
>> >>>>>> checking for additional include dirs...
>> >>>>>> checking for additional library dirs...
>> >>>>>> checking for a BSD compatible install... /usr/bin/install -c
>> >>>>>> checking for flex... flex
>> >>>>>> checking for yywrap in -lfl... yes
>> >>>>>> checking for bison... bison -y
>> >>>>>> checking for ranlib... ranlib
>> >>>>>> checking for ar... ar
>> >>>>>> checking for env... env
>> >>>>>> checking for perl... /usr/bin/perl
>> >>>>>> checking how to run the C preprocessor... gcc -E
>> >>>>>> checking for ANSI C header files... yes
>> >>>>>> checking for limits.h... yes
>> >>>>>> checking for termio.h... yes
>> >>>>>> checking for termios.h... yes
>> >>>>>> checking for unistd.h... yes
>> >>>>>> checking for values.h... yes
>> >>>>>> checking for f2c.h... yes
>> >>>>>> checking for g2c.h... no
>> >>>>>> checking for sys/ioctl.h... yes
>> >>>>>> checking for sys/mtio.h... yes
>> >>>>>> checking for sys/resource.h... yes
>> >>>>>> checking for sys/time.h... yes
>> >>>>>> checking for sys/timeb.h... yes
>> >>>>>> checking for sys/types.h... yes
>> >>>>>> checking for sys/utsname.h... yes
>> >>>>>> checking for libintl.h... yes
>> >>>>>> checking for iconv.h... yes
>> >>>>>> checking for langinfo.h... yes
>> >>>>>> checking whether time.h and sys/time.h may both be included... yes
>> >>>>>> checking for off_t... yes
>> >>>>>> checking for uid_t in sys/types.h... yes
>> >>>>>> checking return type of signal handlers... void
>> >>>>>> checking for ftime... yes
>> >>>>>> checking for gethostname... yes
>> >>>>>> checking for gettimeofday... yes
>> >>>>>> checking for lseek... yes
>> >>>>>> checking for nice... yes
>> >>>>>> checking for time... yes
>> >>>>>> checking for uname... yes
>> >>>>>> checking for seteuid... yes
>> >>>>>> checking for setpriority... yes
>> >>>>>> checking for setreuid... yes
>> >>>>>> checking for setruid... no
>> >>>>>> checking for drand48... yes
>> >>>>>> checking for putenv... yes
>> >>>>>> checking for setenv... yes
>> >>>>>> checking for nanosleep... yes
>> >>>>>> checking whether setpgrp takes no argument... yes
>> >>>>>> checking for long long int... yes
>> >>>>>> checking for W11... no
>> >>>>>> checking for X... libraries , headers
>> >>>>>> checking for dnet_ntoa in -ldnet... yes
>> >>>>>> checking for gethostbyname... yes
>> >>>>>> checking for connect... yes
>> >>>>>> checking for remove... yes
>> >>>>>> checking for shmat... yes
>> >>>>>> checking for IceConnectionNumber in -lICE... yes
>> >>>>>> checking for library containing cuserid... none required
>> >>>>>> checking for asprintf... yes
>> >>>>>> checking for atan... no
>> >>>>>> checking for atan in -lm... yes
>> >>>>>> checking for dlsym... no
>> >>>>>> checking for dlsym in -ldl... yes
>> >>>>>> checking for iconv... yes
>> >>>>>> checking for socket... yes
>> >>>>>> checking for location of zlib includes...
>> >>>>>> checking for zlib.h... yes
>> >>>>>> checking for location of zlib library...
>> >>>>>> checking for deflate in -lz... yes
>> >>>>>> checking for location of External PROJ.4 includes...
>> >>>>>> checking for proj_api.h... yes
>> >>>>>> checking External PROJ.4 version... 492
>> >>>>>> checking for location of External PROJ.4 library...
>> >>>>>> checking for pj_get_def in -lproj... yes
>> >>>>>> checking for location of External PROJ.4 data files...
>> >>>>>> configure: warning: *** External PROJ.4 directory not specified;
>> >>>>>> default will be used
>> >>>>>> checking for /usr/share/proj/epsg... yes
>> >>>>>> checking for nad2bin... /usr/bin/nad2bin
>> >>>>>> checking whether to use regex... yes
>> >>>>>> checking for location of regex includes...
>> >>>>>> checking for regex.h... yes
>> >>>>>> checking for location of regex library...
>> >>>>>> checking for regcomp... yes
>> >>>>>> checking whether to use Readline... no
>> >>>>>> checking whether to use GDAL... yes
>> >>>>>> checking for gdal-config... /usr/local/bin/gdal-config
>> >>>>>> checking whether to use libLAS... no
>> >>>>>> checking whether to use NetCDF... no
>> >>>>>> checking whether to use GEOS... no
>> >>>>>> checking whether to use TIFF... yes
>> >>>>>> checking for location of TIFF includes...
>> >>>>>> checking for tiffio.h... yes
>> >>>>>> checking for location of TIFF library...
>> >>>>>> checking for TIFFOpen in -ltiff... yes
>> >>>>>> checking whether to use PNG... yes
>> >>>>>> checking for location of PNG includes...
>> >>>>>> checking for png.h... yes
>> >>>>>> checking for location of PNG library...
>> >>>>>> checking for png_read_image in -lpng... yes
>> >>>>>> checking whether to use PostgreSQL... no
>> >>>>>> checking whether to use MySQL... no
>> >>>>>> checking whether to use SQLite... yes
>> >>>>>> checking for location of SQLite includes...
>> >>>>>> checking for sqlite3.h... yes
>> >>>>>> checking for location of SQLite library...
>> >>>>>> checking for sqlite3_open in -lsqlite3... yes
>> >>>>>> checking whether to use OpenGL... yes
>> >>>>>> checking for location of OpenGL includes...
>> >>>>>> checking for GL/gl.h... yes
>> >>>>>> checking for GL/glu.h... yes
>> >>>>>> checking for location of OpenGL library...
>> >>>>>> checking for glBegin in -lGL... yes
>> >>>>>> checking for gluBeginCurve in -lGLU... yes
>> >>>>>> checking for glXCreatePbuffer... yes
>> >>>>>> checking for glXCreateGLXPixmap... yes
>> >>>>>> checking whether to use ODBC... no
>> >>>>>> checking whether to use FFTW... yes
>> >>>>>> checking for location of FFTW includes...
>> >>>>>> checking for fftw3.h... yes
>> >>>>>> checking for location of FFTW library...
>> >>>>>> checking for fftw_execute in -lfftw3... yes
>> >>>>>> checking whether to use BLAS... no
>> >>>>>> checking whether to use LAPACK... no
>> >>>>>> checking whether to use Cairo... yes
>> >>>>>> checking for location of cairo includes...
>> >>>>>> checking for cairo.h... yes
>> >>>>>> checking for location of cairo library...
>> >>>>>> checking for cairo linking flags...
>> >>>>>> checking for cairo_create... yes
>> >>>>>> checking for cairo_xlib_surface_create_with_xrender_format... yes
>> >>>>>> checking for cairo_xlib_surface_get_xrender_format... yes
>> >>>>>> checking whether to use FreeType... yes
>> >>>>>> checking for location of FreeType includes...
>> >>>>>> checking for ft2build.h... no
>> >>>>>> configure: error: *** Unable to locate FreeType includes.
>> >>>>>> jiapei:grass-7.0.4$
>> >>>>> Cheers
>> >>>>> Pei JIA, Ph.D.
>> >>>>> Email: jp4work at gmail.com
>> >>>>> cell in Canada: +1 778-863-5816
>> >>>>> cell in China: +86 186-8244-3503
>> >>>>> Welcome to Vision Open
>> >>>>> http://www.visionopen.com
>> >>>>> _______________________________________________
>> >>>>> grass-user mailing list
>> >>>>> grass-user at lists.osgeo.org
>> >>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> >>> Pei JIA, Ph.D.
>> > Pei JIA, Ph.D.
> Pei JIA, Ph.D.
