[GRASS-user] Fail to configure grass-7.0.4 under Ubuntu 16.04.1
    Anna Petrášová
    kratochanna at gmail.com
    Thu Sep 29 18:29:45 PDT 2016
On Thu, Sep 29, 2016 at 9:22 PM, JIA Pei <jp4work at gmail.com> wrote:
> Are you sure you are using Python3 only?
No, I use Python 2.7. Sorry, I missed you use Python 3. Most parts of
GRASS should work with Python 3, but I haven't tested myself. GUI
won't work, because wxPython classic is for 2.7 only.
> On Thu, Sep 29, 2016 at 5:51 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Thu, Sep 29, 2016 at 8:35 PM, JIA Pei <jp4work at gmail.com> wrote:
>> > Thanks Anna:
>> > Now, I got the following error.log :
>> > Any further suggestions????
>> do what it suggests:
>> "In case of errors please change into the directory with error and run
>> 'make'.
>> If you get multiple errors, you need to deal with them in the order they
>> appear in the error log. If you get an error building a library, you will
>> also get errors from anything which uses the library."
>> and post the errors here. Anything special about your system
>> configuration? I was just compiling GRASS on Ubuntu 16.04 without
>> problems.
>> Anna
>> >> GRASS GIS 7.3.svn r69608 compilation log
>> >> Started compilation: Thu Sep 29 17:30:12 PDT 2016
>> >> Errors in:
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/pngdriver
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/psdriver
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/htmldriver
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/cairodriver
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/db/sqlp
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/vector
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/imagery
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/cluster
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/rst/interp_float
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/lidar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/raster3d/test
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/init
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/ogsf
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/nviz
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/exceptions
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/script
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/ctypes
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/temporal
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/pygrass
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/pydispatch
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/imaging
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/python/gunittest
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/lib/manage
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/db
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.fontlist
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.erase
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.colorlist
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.geodesic
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.colortable
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.graph
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.barscale
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.info
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.his
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.labels
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.path
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.histogram
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.legend.vect
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.linegraph
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.grid
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.profile
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.rast
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.northarrow
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.rgb
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.rast.arrow
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.rast.num
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.vect
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.vect.chart
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.vect.thematic
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.mon
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.rhumbline
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.text
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.title
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/display/d.where
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.findfile
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.copy
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.list
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.findetc
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.dirseps
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.gui
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.gisenv
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.filename
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.cairocomp
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.access
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.mapset
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.message
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.region
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.remove
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.pnmcomp
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.mapsets
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.rename
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.ppmtopng
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.parser
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.tempfile
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.version
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/manage/lister
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.mkfontcap
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/general/g.proj
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.in.lidar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.in.ascii
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.in.bin
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.cross.rast
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.gradient
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.gwflow
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.info
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.in.v5d
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.mask
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.null
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.flow
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.out.ascii
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.neighbors
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.out.bin
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.mkdspf
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.retile
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.stats
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.support
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.timestamp
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.out.vtk
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.out.netcdf
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.to.rast
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/raster3d/r3.out.v5d
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.build
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.class
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.buffer
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.build.polylines
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.category
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.colors
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.clean
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.cluster
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.colors.out
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.db.connect
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.db.select
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.distance
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.drape
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.delaunay
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.decimate
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.extract
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.extrude
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.edit
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.generalize
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.hull
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.info
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.ascii
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.db
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.dxf
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.label
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.lidar.correction
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.lidar.edgedetection
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.kcv
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.kernel
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.lidar.growing
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.proj
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.mkgrid
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.alloc
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.neighbors
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.centrality
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.allpairs
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.bridge
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.connectivity
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.components
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.distance
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.flow
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.path
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.salesman
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.iso
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.spanningtree
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.normal
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.steiner
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.visibility
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.ascii
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.net.timetable
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.dxf
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.lidar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.vtk
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.svg
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.pov
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.overlay
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.outlier
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.perturb
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.parallel
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.patch
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.split
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.qcount
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.random
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.reclass
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.sample
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.rectify
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.support
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.select
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.surf.bspline
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.surf.rst
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.lrs
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.surf.idw
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.region
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.to.db
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.to.rast
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.to.3d
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.to.rast3
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.type
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.univar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.voronoi
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.what
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.what.rast
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.what.rast3
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.vect.stats
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.vol.rst
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.out.ogr
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.ogr
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.external
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.in.lidar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.transform
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.segment
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.timestamp
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.to.points
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/vector/v.external.out
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/misc/m.transform
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/misc/m.nviz.image
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/misc/m.measure
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/misc/m.cogo
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/misc/m.nviz.script
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.cca
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.cluster
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.eb.eta
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.biomass
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.eb.evapfr
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.aster.toar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.albedo
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.eb.hsebal01
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.eb.netrad
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.eb.soilheatflux
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.gensig
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.evapo.time
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.evapo.pm
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.gensigset
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.group
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.evapo.mh
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.evapo.pt
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.emissivity
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.maxlik
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.rectify
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.his.rgb
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.segment
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.smap
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.target
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.landsat.acca
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.rgb.his
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.pca
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.landsat.toar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.topo.corr
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.fft
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.ifft
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.zc
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.ortho.photo/lib
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.ortho.photo/i.ortho.camera
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.ortho.photo/i.ortho.elev
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.ortho.photo/i.ortho.rectify
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.vi
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.atcorr
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/imagery/i.modis.qc
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/ps/ps.map
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.correlate
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.redraw
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.rast.edit
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.to.rast
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.rast.leg
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.out.file
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.frame
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.polar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.shade
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.in.ogr
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.what.vect
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/d.what.rast
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.droptable
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.dropcolumn
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.test
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.out.ogr
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/db.univar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/g.extension.all
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/g.search.modules
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.colors.enhance
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/g.manual
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.in.spotvgt
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.image.mosaic
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.oif
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.spectral
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/m.proj
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.tasscap
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.colors.stddev
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.buffer.lowmem
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.blend
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/i.pansharpen
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.in.wms
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.fillnulls
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.import
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.grow
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.in.srtm
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.in.aster
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.mask
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.out.xyz
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.pack
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.reclass.area
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.plane
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.shade
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.rgb
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.unpack
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r.tileset
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/r3.in.xyz
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.addcolumn
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.join
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.centroids
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.build.all
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.dropcolumn
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.addtable
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.droprow
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.droptable
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.univar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.renamecolumn
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.reconnect.all
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.import
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.db.update
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.in.e00
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.in.geonames
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.dissolve
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.in.mapgen
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.in.lines
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.report
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.pack
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.rast.stats
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.what.strds
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.to.lines
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.unpack
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.in.wfs
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/v.what.vect
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/scripts/wxpyimgview
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.connect
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.remove
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.create
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.list
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.topology
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.merge
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.support
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.info
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.accdetect
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.accumulate
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.aggregate
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.unregister
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.register
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.sample
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.aggregate.ds
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.colors
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.contour
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.mapcalc
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.list
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.to.rast3
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.univar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.neighbors
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.series
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.algebra
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.export
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.gapfill
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.out.vtk
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.extract
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.to.vect
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.what
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast.import
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast3d.list
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast3d.extract
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast3d.mapcalc
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rename
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast3d.algebra
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.rast3d.univar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.snap
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.shift
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.select
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.list
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.export
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.db.select
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.algebra
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.import
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.what.strds
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.extract
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.observe.strds
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/temporal/t.vect.univar
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/doc
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/gui/wxpython
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/visualization/ximgview
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/locale
>> >> ......//rsgis/OSGeo/grass/grass7_trunk/man
>> >> 'make'.
>> >> they
>> >> will
>> >> Finished compilation: Thu Sep 29 17:31:30 PDT 2016
>> > cheers
>> > On Wed, Sep 28, 2016 at 4:56 PM, Anna Petrášová <kratochanna at gmail.com>
>> > wrote:
>> >> On Wed, Sep 28, 2016 at 7:41 PM, JIA Pei <jp4work at gmail.com> wrote:
>> >> > My working Environment:     Ubuntu 16.04.1 + GCC/G++ 5.4.0
>> >> > I now moves to grass 7.3 SVN, which seems to be the right version I
>> >> > should
>> >> > go for????
>> >> > It seems I can do the following configuration directly...
>> >> > It seems OpenDWG has already been replaced by LibreDWG ??? Any plan
>> >> > to
>> >> > have
>> >> > OpenDWG upgraded to LibreDWG???
>> >> > CFLAGS="-O2 -Wall -fPIC" CXXFLAGS="-O2 -Wall -fPIC"  LDFLAGS="-s"
>> >> > ./configure \
>> >> >     --enable-largefile=yes \
>> >> >     --with-blas=yes --with-blas-includes=/usr/include
>> >> > --with-blas-libs=/usr/lib/libblas/ \
>> >> >     --with-lapack=yes --with-lapack-includes=
>> >> > --with-lapack-libs=/usr/lib/lapack \
>> >> >     --with-netcdf= \
>> >> >     --with-readline=yes
>> >> > --with-readline-includes=/usr/include/readline
>> >> > --with-readline-libs=/usr/lib/x86_64-linux-gnu \
>> >> >     --with-openmp=yes --with-openmp-includes=/usr/lib/openmpi/include
>> >> > --with-openmp-libs=/usr/lib/openmpi/lib \
>> >> >     --with-pthread=yes --with-pthread-includes= --with-pthread-libs=
>> >> >     --with-liblas=/usr/local/bin/liblas-config \
>> >> >     --with-libredwg=yes --with-libredwg-includes=/usr/local/include
>> >> > --with-libredwg-libs=/usr/local/lib \
>> >> >     --with-nls \
>> >> >     --with-cxx \
>> >> >     --with-proj-share=/usr/share/proj/ \
>> >> >     --with-geos \
>> >> >     --with-wxwidgets \
>> >> >     --with-cairo \
>> >> >     --with-opengl-libs=/usr/include/GL \
>> >> >     --with-freetype=yes
>> >> > --with-freetype-includes="/usr/include/freetype2/" \
>> >> >     --with-postgres=no \
>> >> >     --with-sqlite=yes \
>> >> >     --with-mysql=yes --with-mysql-includes="/usr/include/mysql" \
>> >> >     --with-odbc=no \
>> >> >     --with-bzlib=yes --with-bzlib-includes=/usr/include
>> >> > --with-bzlib-libs=/usr/lib/x86_64-linux-gnu \
>> >> >     --with-opencl=yes --with-opencl-includes=/usr/local/cuda/include
>> >> > --with-opencl-libs=/usr/local/cuda/lib64 \
>> >> >      2>&1 | tee config_log.txt
>> >> > GRASS is now configured for:  x86_64-pc-linux-gnu
>> >> >  Source directory:
>> >> > /home/jiapei/Downloads/rsgis/OSGeo/grass/grass-7.3
>> >> >  Build directory:
>> >> >  Installation directory:     ${prefix}/grass-7.3.svn
>> >> >  Startup script in directory:${exec_prefix}/bin
>> >> >  C compiler:                 gcc -O2 -Wall -fPIC
>> >> >  C++ compiler:               c++ -O2 -Wall -fPIC
>> >> >  Building shared libraries:  yes
>> >> >  OpenGL platform:            X11
>> >> >  MacOSX application:         no
>> >> >  MacOSX architectures:
>> >> >  MacOSX SDK:
>> >> >  BLAS support:               yes
>> >> >  BZIP2 support:              yes
>> >> >  C++ support:                yes
>> >> >  Cairo support:              yes
>> >> >  DWG support:                no
>> >> >  FFTW support:               yes
>> >> >  FreeType support:           yes
>> >> >  GDAL support:               yes
>> >> >  GEOS support:               yes
>> >> >  LAPACK support:             yes
>> >> >  Large File support (LFS):   yes
>> >> >  libLAS support:             yes
>> >> >  MySQL support:              yes
>> >> >  NetCDF support:             yes
>> >> >  NLS support:                yes
>> >> >  ODBC support:               no
>> >> >  OGR support:                yes
>> >> >  OpenCL support:             yes
>> >> >  OpenGL support:             yes
>> >> >  OpenMP support:             yes
>> >> >  PDAL support:               no
>> >> >  PNG support:                yes
>> >> >  POSIX thread support:       yes
>> >> >  PostgreSQL support:         no
>> >> >  Readline support:           yes
>> >> >  Regex support:              yes
>> >> >  SQLite support:             yes
>> >> >  TIFF support:               yes
>> >> >  X11 support:                yes
>> >> > However, it fails to build...
>> >> > GISBASE="....../grass/grass-7.3/dist.x86_64-pc-linux-gnu"
>> >> > ARCH="x86_64-pc-linux-gnu"
>> >> > ARCH_DISTDIR="....../grass/grass-7.3/dist.x86_64-pc-linux-gnu"
>> >> > VERSION_NUMBER=7.3.svn VERSION_DATE=2016 python ./build_full_index.py
>> >> >   File "./build_full_index.py", line 35
>> >> >     classes.append((prefix, class_labels.get(prefix, prefix)))
>> >> > TabError: inconsistent use of tabs and spaces in indentation
>> >> Please try again, I just fixed it.
>> >> Anna
>> >> > Makefile:105: recipe for target
>> >> > '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/docs/html/full_index.html'
>> >> > failed
>> >> > make[3]: ***
>> >> > [....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/docs/html/full_index.html]
>> >> > Error 1
>> >> > make[3]: Leaving directory '....../grass/grass-7.3/man'
>> >> > Makefile:43: recipe for target 'default' failed
>> >> > make[2]: *** [default] Error 2
>> >> > make[2]: Leaving directory '....../grass/grass-7.3/man'
>> >> > make[2]: Entering directory '....../grass/grass-7.3/macosx'
>> >> > make[2]: Leaving directory '....../grass/grass-7.3/macosx'
>> >> > make[2]: Entering directory '....../grass/grass-7.3/mswindows'
>> >> > make[2]: Nothing to be done for 'first'.
>> >> > make[2]: Leaving directory '....../grass/grass-7.3/mswindows'
>> >> > make[1]: Leaving directory '....../grass/grass-7.3'
>> >> > make ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/AUTHORS
>> >> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/CHANGES
>> >> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/CITING
>> >> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/COPYING
>> >> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/GPL.TXT
>> >> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/INSTALL
>> >> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/REQUIREMENTS.html
>> >> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/contributors.csv
>> >> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/contributors_extra.csv
>> >> > ....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/translators.csv
>> >> > make[1]: Entering directory '....../grass/grass-7.3'
>> >> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/AUTHORS' is
>> >> > up
>> >> > to
>> >> > date.
>> >> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/CHANGES' is
>> >> > up
>> >> > to
>> >> > date.
>> >> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/CITING' is
>> >> > up
>> >> > to
>> >> > date.
>> >> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/COPYING' is
>> >> > up
>> >> > to
>> >> > date.
>> >> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/GPL.TXT' is
>> >> > up
>> >> > to
>> >> > date.
>> >> > make[1]: '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/INSTALL' is
>> >> > up
>> >> > to
>> >> > date.
>> >> > make[1]:
>> >> > '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/REQUIREMENTS.html'
>> >> > is up to date.
>> >> > make[1]:
>> >> > '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/contributors.csv'
>> >> > is up to date.
>> >> > make[1]:
>> >> > '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/contributors_extra.csv'
>> >> > is
>> >> > up to date.
>> >> > make[1]:
>> >> > '....../grass/grass-7.3/dist.x86_64-pc-linux-gnu/translators.csv'
>> >> > is up to date.
>> >> > make manifests
>> >> > make[1]: Nothing to be done for 'manifests'.
>> >> > GRASS GIS 7.3.svn r69562M compilation log
>> >> > Started compilation: Wed Sep 28 16:37:18 PDT 2016
>> >> > Errors in:
>> >> > ....../grass/grass-7.3/lib/pngdriver
>> >> > ....../grass/grass-7.3/lib/psdriver
>> >> > ....../grass/grass-7.3/lib/htmldriver
>> >> > ....../grass/grass-7.3/lib/cairodriver
>> >> > ....../grass/grass-7.3/lib/db/sqlp
>> >> > ....../grass/grass-7.3/lib/vector
>> >> > ....../grass/grass-7.3/lib/imagery
>> >> > ....../grass/grass-7.3/lib/cluster
>> >> > ....../grass/grass-7.3/lib/rst/interp_float
>> >> > ....../grass/grass-7.3/lib/lidar
>> >> > ....../grass/grass-7.3/lib/raster3d/test
>> >> > ....../grass/grass-7.3/lib/ogsf
>> >> > ....../grass/grass-7.3/lib/nviz
>> >> > ....../grass/grass-7.3/lib/python/exceptions
>> >> > ....../grass/grass-7.3/lib/python/script
>> >> > ....../grass/grass-7.3/lib/python/ctypes
>> >> > ....../grass/grass-7.3/lib/python/temporal
>> >> > ....../grass/grass-7.3/lib/python/pygrass
>> >> > ....../grass/grass-7.3/lib/python/pydispatch
>> >> > ....../grass/grass-7.3/lib/python/imaging
>> >> > ....../grass/grass-7.3/lib/python/gunittest
>> >> > ....../grass/grass-7.3/lib/manage
>> >> > ....../grass/grass-7.3/db
>> >> > ....../grass/grass-7.3/display
>> >> > ....../grass/grass-7.3/general/g.access
>> >> > ....../grass/grass-7.3/general/g.cairocomp
>> >> > ....../grass/grass-7.3/general/g.copy
>> >> > ....../grass/grass-7.3/general/g.dirseps
>> >> > ....../grass/grass-7.3/general/g.filename
>> >> > ....../grass/grass-7.3/general/g.findetc
>> >> > ....../grass/grass-7.3/general/g.findfile
>> >> > ....../grass/grass-7.3/general/g.gisenv
>> >> > ....../grass/grass-7.3/general/g.gui
>> >> > ....../grass/grass-7.3/general/g.list
>> >> > ....../grass/grass-7.3/general/g.mapset
>> >> > ....../grass/grass-7.3/general/g.mapsets
>> >> > ....../grass/grass-7.3/general/g.message
>> >> > ....../grass/grass-7.3/general/g.mkfontcap
>> >> > ....../grass/grass-7.3/general/g.parser
>> >> > ....../grass/grass-7.3/general/g.pnmcomp
>> >> > ....../grass/grass-7.3/general/g.ppmtopng
>> >> > ....../grass/grass-7.3/general/g.proj
>> >> > ....../grass/grass-7.3/general/g.region
>> >> > ....../grass/grass-7.3/general/g.remove
>> >> > ....../grass/grass-7.3/general/g.rename
>> >> > ....../grass/grass-7.3/general/g.tempfile
>> >> > ....../grass/grass-7.3/general/g.version
>> >> > ....../grass/grass-7.3/general/manage/lister
>> >> > ....../grass/grass-7.3/raster
>> >> > ....../grass/grass-7.3/raster3d
>> >> > ....../grass/grass-7.3/vector
>> >> > ....../grass/grass-7.3/misc/m.cogo
>> >> > ....../grass/grass-7.3/misc/m.measure
>> >> > ....../grass/grass-7.3/misc/m.nviz.image
>> >> > ....../grass/grass-7.3/misc/m.nviz.script
>> >> > ....../grass/grass-7.3/misc/m.transform
>> >> > ....../grass/grass-7.3/imagery
>> >> > ....../grass/grass-7.3/ps/ps.map
>> >> > ....../grass/grass-7.3/scripts/d.correlate
>> >> > ....../grass/grass-7.3/scripts/d.frame
>> >> > ....../grass/grass-7.3/scripts/d.out.file
>> >> > ....../grass/grass-7.3/scripts/d.to.rast
>> >> > ....../grass/grass-7.3/scripts/d.polar
>> >> > ....../grass/grass-7.3/scripts/d.rast.edit
>> >> > ....../grass/grass-7.3/scripts/d.rast.leg
>> >> > ....../grass/grass-7.3/scripts/d.redraw
>> >> > ....../grass/grass-7.3/scripts/d.shade
>> >> > ....../grass/grass-7.3/scripts/d.what.rast
>> >> > ....../grass/grass-7.3/scripts/d.what.vect
>> >> > ....../grass/grass-7.3/scripts/db.dropcolumn
>> >> > ....../grass/grass-7.3/scripts/db.droptable
>> >> > ....../grass/grass-7.3/scripts/db.in.ogr
>> >> > ....../grass/grass-7.3/scripts/db.out.ogr
>> >> > ....../grass/grass-7.3/scripts/db.test
>> >> > ....../grass/grass-7.3/scripts/db.univar
>> >> > ....../grass/grass-7.3/scripts/g.extension
>> >> > ....../grass/grass-7.3/scripts/g.extension.all
>> >> > ....../grass/grass-7.3/scripts/g.manual
>> >> > ....../grass/grass-7.3/scripts/g.search.modules
>> >> > ....../grass/grass-7.3/scripts/i.colors.enhance
>> >> > ....../grass/grass-7.3/scripts/i.image.mosaic
>> >> > ....../grass/grass-7.3/scripts/i.in.spotvgt
>> >> > ....../grass/grass-7.3/scripts/i.oif
>> >> > ....../grass/grass-7.3/scripts/i.pansharpen
>> >> > ....../grass/grass-7.3/scripts/i.spectral
>> >> > ....../grass/grass-7.3/scripts/i.tasscap
>> >> > ....../grass/grass-7.3/scripts/m.proj
>> >> > ....../grass/grass-7.3/scripts/r.blend
>> >> > ....../grass/grass-7.3/scripts/r.buffer.lowmem
>> >> > ....../grass/grass-7.3/scripts/r.colors.stddev
>> >> > ....../grass/grass-7.3/scripts/r.fillnulls
>> >> > ....../grass/grass-7.3/scripts/r.grow
>> >> > ....../grass/grass-7.3/scripts/r.import
>> >> > ....../grass/grass-7.3/scripts/r.in.aster
>> >> > ....../grass/grass-7.3/scripts/r.in.srtm
>> >> > ....../grass/grass-7.3/scripts/r.in.wms
>> >> > ....../grass/grass-7.3/scripts/r.mask
>> >> > ....../grass/grass-7.3/scripts/r.out.xyz
>> >> > ....../grass/grass-7.3/scripts/r.pack
>> >> > ....../grass/grass-7.3/scripts/r.plane
>> >> > ....../grass/grass-7.3/scripts/r.reclass.area
>> >> > ....../grass/grass-7.3/scripts/r.rgb
>> >> > ....../grass/grass-7.3/scripts/r.shade
>> >> > ....../grass/grass-7.3/scripts/r.tileset
>> >> > ....../grass/grass-7.3/scripts/r.unpack
>> >> > ....../grass/grass-7.3/scripts/r3.in.xyz
>> >> > ....../grass/grass-7.3/scripts/v.build.all
>> >> > ....../grass/grass-7.3/scripts/v.centroids
>> >> > ....../grass/grass-7.3/scripts/v.db.addcolumn
>> >> > ....../grass/grass-7.3/scripts/v.db.addtable
>> >> > ....../grass/grass-7.3/scripts/v.db.join
>> >> > ....../grass/grass-7.3/scripts/v.db.dropcolumn
>> >> > ....../grass/grass-7.3/scripts/v.db.droprow
>> >> > ....../grass/grass-7.3/scripts/v.db.droptable
>> >> > ....../grass/grass-7.3/scripts/v.db.renamecolumn
>> >> > ....../grass/grass-7.3/scripts/v.db.reconnect.all
>> >> > ....../grass/grass-7.3/scripts/v.db.univar
>> >> > ....../grass/grass-7.3/scripts/v.db.update
>> >> > ....../grass/grass-7.3/scripts/v.dissolve
>> >> > ....../grass/grass-7.3/scripts/v.import
>> >> > ....../grass/grass-7.3/scripts/v.in.e00
>> >> > ....../grass/grass-7.3/scripts/v.in.geonames
>> >> > ....../grass/grass-7.3/scripts/v.in.lines
>> >> > ....../grass/grass-7.3/scripts/v.in.mapgen
>> >> > ....../grass/grass-7.3/scripts/v.in.wfs
>> >> > ....../grass/grass-7.3/scripts/v.rast.stats
>> >> > ....../grass/grass-7.3/scripts/v.report
>> >> > ....../grass/grass-7.3/scripts/v.pack
>> >> > ....../grass/grass-7.3/scripts/v.to.lines
>> >> > ....../grass/grass-7.3/scripts/v.unpack
>> >> > ....../grass/grass-7.3/scripts/v.what.strds
>> >> > ....../grass/grass-7.3/scripts/v.what.vect
>> >> > ....../grass/grass-7.3/scripts/wxpyimgview
>> >> > ....../grass/grass-7.3/temporal
>> >> > ....../grass/grass-7.3/gui/wxpython
>> >> > ....../grass/grass-7.3/visualization/ximgview
>> >> > ....../grass/grass-7.3/locale
>> >> > 'make'.
>> >> > they
>> >> > will
>> >> > Finished compilation: Wed Sep 28 16:37:31 PDT 2016
>> >> > Makefile:57: recipe for target 'default' failed
>> >> > make: *** [default] Error 1
>> >> > jiapei:grass-7.3$
>> >> > On Wed, Sep 28, 2016 at 4:56 AM, Thomas Adams <tea3rd at gmail.com>
>> >> > wrote:
>> >> >> You can compile with hdf5... not a problem; same with python3, I
>> >> >> believe
>> >> >> Tom
>> >> >> On Wed, Sep 28, 2016 at 7:05 AM, JIA Pei <jp4work at gmail.com> wrote:
>> >> >>> By this command " sudo apt-get build-dep grass", I got:
>> >> >>>> The following NEW packages will be installed:
>> >> >>>>  autoconf2.13 libgdal-dev libgdal1i libhdf4-0-alt libhdf4-alt-dev
>> >> >>>> liblas-c-dev liblas-c3 liblas-dev liblas3 netcdf-bin python-pil
>> >> >>>> python-ply
>> >> >>>> python-wxgtk3.0 python-wxversion
>> >> >>> But, unfortunately,
>> >> >>> 1)  installed my own libgdal-dev, instead of Ubuntu's default one
>> >> >>> from
>> >> >>> repository
>> >> >>> 2)  I NEVER use libhdf4, clearly I prefer libhdf5
>> >> >>> 3) I use Python 3.5.2, instead of python 2
>> >> >>> 4) liblas from repository requires libgdal-dev from repository, and
>> >> >>> relies on libhdf4 ....
>> >> >>> So, will grass move to
>> >> >>> Python3
>> >> >>> libhdf5
>> >> >>> Cheers
>> >> >>> On Tue, Sep 27, 2016 at 6:41 PM, Thomas Adams <tea3rd at gmail.com>
>> >> >>> wrote:
>> >> >>>> Go here:
>> >> >>>> https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
>> >> >>>> Look at this:
>> >> >>>>  tar xzf grass-7.0.4.tar.gz
>> >> >>>>  cd grass-7.0.4/
>> >> >>>>  # install build dependency packages:
>> >> >>>>  # configure to taste..
>> >> >>>> CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
>> >> >>>>     --with-nls \
>> >> >>>>     --with-cxx \
>> >> >>>>     --with-geos \
>> >> >>>>     --with-wxwidgets \
>> >> >>>>     --with-cairo \
>> >> >>>>     --with-freetype=yes
>> >> >>>>     --with-postgres=yes
>> >> >>>> --with-postgres-includes="/usr/include/postgresql" \
>> >> >>>>     --with-sqlite=yes \
>> >> >>>>     --with-odbc=no \
>> >> >>>>  # build using 4 CPU cores
>> >> >>>>  time make -j 4 2>&1 | tee build_log.txt
>> >> >>>>  sudo make install
>> >> >>>> Tom
>> >> >>>> On Tue, Sep 27, 2016 at 8:34 PM, JIA Pei <jp4work at gmail.com>
>> >> >>>> wrote:
>> >> >>>>> Hi, all:
>> >> >>>>> I failed to configure grass-7.0.4, can anybody give me a hand?
>> >> >>>>> OS: Ubuntu 16.04.1
>> >> >>>>> GCC/G++: Ubuntu 5.4.0-6ubuntu1~16.04.2
>> >> >>>>> FreeType: libfreetype6 2.6.1-0.1ubuntu2
>> >> >>>>>> jiapei:grass-7.0.4$ ./configure
>> >> >>>>>> checking host system type... x86_64-pc-linux-gnu
>> >> >>>>>> checking for gcc... gcc
>> >> >>>>>> checking whether the C compiler (gcc  ) works... yes
>> >> >>>>>> checking whether the C compiler (gcc  ) is a cross-compiler...
>> >> >>>>>> no
>> >> >>>>>> checking whether we are using GNU C... yes
>> >> >>>>>> checking whether gcc accepts -g... yes
>> >> >>>>>> checking for Cygwin environment... no
>> >> >>>>>> checking for mingw32 environment... no
>> >> >>>>>> checking for executable suffix... no
>> >> >>>>>> checking for full floating-point support... yes
>> >> >>>>>> checking for pwd... /bin/pwd
>> >> >>>>>> checking for source directory...
>> >> >>>>>> /home/jiapei/Downloads/rsgis/OSGeo/grass/grass-7.0.4
>> >> >>>>>> checking for build directory...
>> >> >>>>>> checking for svnversion... /usr/bin/svnversion
>> >> >>>>>> checking for MacOSX App... no
>> >> >>>>>> checking for MacOSX architectures... no
>> >> >>>>>> checking for MacOSX SDK... no
>> >> >>>>>> checking how to build libraries... shared
>> >> >>>>>> checking for additional include dirs...
>> >> >>>>>> checking for additional library dirs...
>> >> >>>>>> checking for a BSD compatible install... /usr/bin/install -c
>> >> >>>>>> checking for flex... flex
>> >> >>>>>> checking for yywrap in -lfl... yes
>> >> >>>>>> checking for bison... bison -y
>> >> >>>>>> checking for ranlib... ranlib
>> >> >>>>>> checking for ar... ar
>> >> >>>>>> checking for env... env
>> >> >>>>>> checking for perl... /usr/bin/perl
>> >> >>>>>> checking how to run the C preprocessor... gcc -E
>> >> >>>>>> checking for ANSI C header files... yes
>> >> >>>>>> checking for limits.h... yes
>> >> >>>>>> checking for termio.h... yes
>> >> >>>>>> checking for termios.h... yes
>> >> >>>>>> checking for unistd.h... yes
>> >> >>>>>> checking for values.h... yes
>> >> >>>>>> checking for f2c.h... yes
>> >> >>>>>> checking for g2c.h... no
>> >> >>>>>> checking for sys/ioctl.h... yes
>> >> >>>>>> checking for sys/mtio.h... yes
>> >> >>>>>> checking for sys/resource.h... yes
>> >> >>>>>> checking for sys/time.h... yes
>> >> >>>>>> checking for sys/timeb.h... yes
>> >> >>>>>> checking for sys/types.h... yes
>> >> >>>>>> checking for sys/utsname.h... yes
>> >> >>>>>> checking for libintl.h... yes
>> >> >>>>>> checking for iconv.h... yes
>> >> >>>>>> checking for langinfo.h... yes
>> >> >>>>>> checking whether time.h and sys/time.h may both be included...
>> >> >>>>>> yes
>> >> >>>>>> checking for off_t... yes
>> >> >>>>>> checking for uid_t in sys/types.h... yes
>> >> >>>>>> checking return type of signal handlers... void
>> >> >>>>>> checking for ftime... yes
>> >> >>>>>> checking for gethostname... yes
>> >> >>>>>> checking for gettimeofday... yes
>> >> >>>>>> checking for lseek... yes
>> >> >>>>>> checking for nice... yes
>> >> >>>>>> checking for time... yes
>> >> >>>>>> checking for uname... yes
>> >> >>>>>> checking for seteuid... yes
>> >> >>>>>> checking for setpriority... yes
>> >> >>>>>> checking for setreuid... yes
>> >> >>>>>> checking for setruid... no
>> >> >>>>>> checking for drand48... yes
>> >> >>>>>> checking for putenv... yes
>> >> >>>>>> checking for setenv... yes
>> >> >>>>>> checking for nanosleep... yes
>> >> >>>>>> checking whether setpgrp takes no argument... yes
>> >> >>>>>> checking for long long int... yes
>> >> >>>>>> checking for W11... no
>> >> >>>>>> checking for X... libraries , headers
>> >> >>>>>> checking for dnet_ntoa in -ldnet... yes
>> >> >>>>>> checking for gethostbyname... yes
>> >> >>>>>> checking for connect... yes
>> >> >>>>>> checking for remove... yes
>> >> >>>>>> checking for shmat... yes
>> >> >>>>>> checking for IceConnectionNumber in -lICE... yes
>> >> >>>>>> checking for library containing cuserid... none required
>> >> >>>>>> checking for asprintf... yes
>> >> >>>>>> checking for atan... no
>> >> >>>>>> checking for atan in -lm... yes
>> >> >>>>>> checking for dlsym... no
>> >> >>>>>> checking for dlsym in -ldl... yes
>> >> >>>>>> checking for iconv... yes
>> >> >>>>>> checking for socket... yes
>> >> >>>>>> checking for location of zlib includes...
>> >> >>>>>> checking for zlib.h... yes
>> >> >>>>>> checking for location of zlib library...
>> >> >>>>>> checking for deflate in -lz... yes
>> >> >>>>>> checking for location of External PROJ.4 includes...
>> >> >>>>>> checking for proj_api.h... yes
>> >> >>>>>> checking External PROJ.4 version... 492
>> >> >>>>>> checking for location of External PROJ.4 library...
>> >> >>>>>> checking for pj_get_def in -lproj... yes
>> >> >>>>>> checking for location of External PROJ.4 data files...
>> >> >>>>>> configure: warning: *** External PROJ.4 directory not specified;
>> >> >>>>>> default will be used
>> >> >>>>>> checking for /usr/share/proj/epsg... yes
>> >> >>>>>> checking for nad2bin... /usr/bin/nad2bin
>> >> >>>>>> checking whether to use regex... yes
>> >> >>>>>> checking for location of regex includes...
>> >> >>>>>> checking for regex.h... yes
>> >> >>>>>> checking for location of regex library...
>> >> >>>>>> checking for regcomp... yes
>> >> >>>>>> checking whether to use Readline... no
>> >> >>>>>> checking whether to use GDAL... yes
>> >> >>>>>> checking for gdal-config... /usr/local/bin/gdal-config
>> >> >>>>>> checking whether to use libLAS... no
>> >> >>>>>> checking whether to use NetCDF... no
>> >> >>>>>> checking whether to use GEOS... no
>> >> >>>>>> checking whether to use TIFF... yes
>> >> >>>>>> checking for location of TIFF includes...
>> >> >>>>>> checking for tiffio.h... yes
>> >> >>>>>> checking for location of TIFF library...
>> >> >>>>>> checking for TIFFOpen in -ltiff... yes
>> >> >>>>>> checking whether to use PNG... yes
>> >> >>>>>> checking for location of PNG includes...
>> >> >>>>>> checking for png.h... yes
>> >> >>>>>> checking for location of PNG library...
>> >> >>>>>> checking for png_read_image in -lpng... yes
>> >> >>>>>> checking whether to use PostgreSQL... no
>> >> >>>>>> checking whether to use MySQL... no
>> >> >>>>>> checking whether to use SQLite... yes
>> >> >>>>>> checking for location of SQLite includes...
>> >> >>>>>> checking for sqlite3.h... yes
>> >> >>>>>> checking for location of SQLite library...
>> >> >>>>>> checking for sqlite3_open in -lsqlite3... yes
>> >> >>>>>> checking whether to use OpenGL... yes
>> >> >>>>>> checking for location of OpenGL includes...
>> >> >>>>>> checking for GL/gl.h... yes
>> >> >>>>>> checking for GL/glu.h... yes
>> >> >>>>>> checking for location of OpenGL library...
>> >> >>>>>> checking for glBegin in -lGL... yes
>> >> >>>>>> checking for gluBeginCurve in -lGLU... yes
>> >> >>>>>> checking for glXCreatePbuffer... yes
>> >> >>>>>> checking for glXCreateGLXPixmap... yes
>> >> >>>>>> checking whether to use ODBC... no
>> >> >>>>>> checking whether to use FFTW... yes
>> >> >>>>>> checking for location of FFTW includes...
>> >> >>>>>> checking for fftw3.h... yes
>> >> >>>>>> checking for location of FFTW library...
>> >> >>>>>> checking for fftw_execute in -lfftw3... yes
>> >> >>>>>> checking whether to use BLAS... no
>> >> >>>>>> checking whether to use LAPACK... no
>> >> >>>>>> checking whether to use Cairo... yes
>> >> >>>>>> checking for location of cairo includes...
>> >> >>>>>> checking for cairo.h... yes
>> >> >>>>>> checking for location of cairo library...
>> >> >>>>>> checking for cairo linking flags...
>> >> >>>>>> checking for cairo_create... yes
>> >> >>>>>> checking for cairo_xlib_surface_create_with_xrender_format...
>> >> >>>>>> yes
>> >> >>>>>> checking for cairo_xlib_surface_get_xrender_format... yes
>> >> >>>>>> checking whether to use FreeType... yes
>> >> >>>>>> checking for location of FreeType includes...
>> >> >>>>>> checking for ft2build.h... no
>> >> >>>>>> configure: error: *** Unable to locate FreeType includes.
>> >> >>>>>> jiapei:grass-7.0.4$
>> >> >>>>> Cheers
>> >> >>>>> Pei JIA, Ph.D.
>> >> >>>>> Email: jp4work at gmail.com
>> >> >>>>> cell in Canada:    +1 778-863-5816
>> >> >>>>> cell in China: +86 186-8244-3503
>> >> >>>>> Welcome to Vision Open
>> >> >>>>> http://www.visionopen.com
>> >> >>>>> _______________________________________________
>> >> >>>>> grass-user mailing list
>> >> >>>>> grass-user at lists.osgeo.org
>> >> >>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> >> >>> Pei JIA, Ph.D.
>> >> > Pei JIA, Ph.D.
>> > Pei JIA, Ph.D.
> Pei JIA, Ph.D.
