[GRASS-user] r.import extent=region ignored
Veronica Andreo
veroandreo at gmail.com
Thu Apr 6 12:09:34 PDT 2017
Correction: it is mentioned under 'known issues'... :)
Vero
El 6 abr. 2017 9:05 p. m., "Veronica Andreo" <veroandreo at gmail.com>
escribió:
Hello Thomas,
If the map you are importing has the same projection than the location,
then extent parameter is ignored. It is not a bug, but how the module
works. It is written in the 'Notes' section, I think. The extent parameter
works only when map and target location have different reference systems.
Best,
Vero
El 6 abr. 2017 8:59 p. m., "Tomáš Brunclík" <brunclik at atlas.cz> escribió:
Hello,
Using GRASS 7.2.1svn r70842 (Linux 64bit from today's binary snapshot) and
it seems the extent=region parameter of the r.import is just ignored. Tried
from GUI, then from command line, first with multi band virtual raster,
then with single JPEG2000 file (as in the example below), with and without
the -n option. Is it a known bug, or does it work for someone, perhaps in
some other version, or with other input formats? I tried to look in trac,
but did not see anything. I am aware how I can clip the rasters after
import, but it seemed one of the fine new features which would make the
daily use a little more comfortable...
Tomas Brunclik
GRASS 7.2.1svn (utm33n):~ > r.import -o input=/home/tom/GISdata/DPZ/Ch
lorofyl-vzorkovani/2016-09-13_R122_S2A_samping_09-13/S2A_USE
R_PRD_MSIL2A_PDMC_20160915T151344_R122_V20160913T100022_2016
0913T100504.SAFE/GRANULE/S2A_USER_MSI_L2A_TL_SGS__20160913T
170505_A006411_T33UWR_N02.04/IMG_DATA/R20m/S2A_USER_MSI_
L2A_TL_SGS__20160913T170505_A006411_T33UWR_B04_20m.jp2
output=20160913_R122.3b extent=region
UPOZORNĚNÍ: Přeskakuje se kontrola kartografického zobrazení.
Proceeding with import of 1 raster bands...
Importing raster map <20160913_R122.3b>...
100%
GRASS 7.2.1svn (utm33n):~ > g.region -p
projection: 1 (UTM)
zone: 33
datum: wgs84
ellipsoid: a=6378137 es=0.00669438
north: 5569000
south: 5543320
west: 531260
east: 570320
nsres: 20
ewres: 20
rows: 1284
cols: 1953
cells: 2507652
GRASS 7.2.1svn (utm33n):~ > r.info map=20160913_R122.3b
| Map: 20160913_R122.3b Date: Thu Apr 6 20:27:43
2017 |
| Mapset: sentinel2test Login of Creator:
tom |
| DataBase: /home/tom/GISdata/grass
| Title:
| Timestamp: none
| Type of Map: raster Number of Categories:
0 |
| Data Type: CELL
| Rows: 5490
| Columns: 5490
| Total Cells: 30140100
| Projection: UTM (zone 33)
| N: 5600040 S: 5490240 Res:
20 |
| E: 609780 W: 499980 Res:
20 |
| Range of data: min = 1 max = 17010
| Data Description:
| generated by r.in.gdal
| Comments:
| r.in.gdal -o -k input="/home/tom/GISdata/DPZ/Chlorofyl-vzorkovani/20\
| 16-09-13_R122_S2A_samping_09-13/S2A_USER_PRD_MSIL2A_PDMC_20160915T15\
| 1344_R122_V20160913T100022_20160913T100504.SAFE/GRANULE/S2A_USER_MSI\
| _L2A_TL_SGS__20160913T170505_A006411_T33UWR_N02.04/IMG_DATA/R20m/S2A\
| _USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_B04_20m.jp2"
ou\ |
| tput="20160913_R122.3b" memory=300 offset=0
num_digits=0 |
grass-user mailing list
grass-user at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170406/d62f3c07/attachment-0001.html>
