[GRASS-user] r.mask: no MASK created when using many categories
Mira Kattwinkel
kattwinkel-mira at uni-landau.de
Fri Apr 7 00:56:46 PDT 2017
Dear Anna,
great! Thanks a lot. If I understand it correctly, the limit is now 1024.
Btw, how would I update such a single function? Updating Grass does not
work (linux' apt-get upgrade does not see a new version)?
Mira
On 07/04/17 03:53, Anna Petrášová wrote:
> On Thu, Apr 6, 2017 at 5:47 AM, Micha Silver <tsvibar at gmail.com> wrote:
>> Interesting...
>> I can duplicate the problem (but only up to 100 cats). Above that I get an
>> error of "stack smashing":
> I tried to fix it in r70847 (or at least allow longer sequences, the
> arrays are still statically allocated). But in this case you can also
> use "1 thru 106".
> Anna
>> GRASS 7.2.0 (ITM):~ > r.mask raster=farm_bas maskcats="`seq -s " " 1 100`"
>> --o
>> All subsequent raster operations will be limited to the MASK area. Removing
>> or renaming raster map named 'MASK' will restore raster operations to
>> normal.
>> [Raster MASK present]
>> GRASS 7.2.0 (ITM):~ > r.info -g MASK
>> north=530000
>> south=510000
>> east=185000
>> west=170000
>> nsres=4
>> ewres=4
>> rows=5000
>> cols=3750
>> cells=18750000
>> datatype=CELL
>> ncats=0
>> But with 103 cats...
>> GRASS 7.2.0 (ITM):~ > r.mask raster=farm_bas maskcats="`seq -s " " 1 103`"
>> --o
>> WARNING: MASK already exists and will be overwritten
>> *** stack smashing detected ***: r.reclass terminated
>> normal.
>> ERROR: Raster map <MASK> not found
>> On 04/06/2017 12:12 PM, Mira Kattwinkel wrote:
>> Dear Anna, dear list
>> I used the NC basic sample data set to replicate my case. Unfortunately, I
>> get the same problem. Can anybody give me a hint? Thanks a lot!
>> Here is what I did and the output:
>> r.watershed elevation=elevation at PERMANENT threshold=500 basin=basins_new
>> SECTION 1a (of 5): Initiating Memory.
>> SECTION 1b (of 5): Determining Offmap Flow.
>> SECTION 2: A* Search.
>> SECTION 3a: Accumulating Surface Flow with MFD.
>> SECTION 3b: Adjusting drainage directions.
>> SECTION 4: Watershed determination.
>> SECTION 5: Closing Maps.
>> ## creating mask with 106 categories works fine
>> r.mask raster=basins_new at PERMANENT maskcats=1 2 3 4 5 6 7 8 9 10 11 12 13 14
>> 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39
>> 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64
>> 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89
>> 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
>> normal.
>> r.mapcalc expression=r106 = MASK
>> r.mask -r
>> Raster MASK removed
>> ## creating mask with 107 categories seems to work without error but there
>> is no MASK output
>> 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
>> normal.
>> r.mapcalc expression=m107 = MASK
>> Invalid map <MASK>
>> Parse error
>> ERROR: parse error
>> g.list type=raster
>> basins
>> basins_new
>> elevation
>> elevation_shade
>> geology
>> lakes
>> landuse
>> r106
>> soils
>> On 06/04/17 05:06, Anna Petrášová wrote:
>> On Wed, Apr 5, 2017 at 8:22 AM, Mira Kattwinkel
>> <kattwinkel-mira at uni-landau.de> wrote:
>> Dear List,
>> I am using r.mask to create a new raster map that only contains certain
>> categories given in 'maskcats'. Then, I use r.mapcalc to save the map under
>> a new name and (to be on the save side) delete the MASK with r.mask flag
>> '-r'. I do this in a loop and it works fine until a case when the number of
>> categories to combine is 213 (trail and error lead to 106 as the maximum
>> number that works fine). Flag 'verbose' gives the message that a MASK was
>> created, but none is there. The problem arises in both cases when I directly
>> use Grass or through R using execGrass.
>> I tried it on landsat raster from NC sample dataset and it worked.
>> Perhaps you could try to replicate it with this sample dataset?
>> Anna
>> Is there a limit in the number of categories that can be passed to r.mask? I
>> did not find any hint about that. Additionally, I wonder why there is no
>> error message but in the contrary one that tells me that a MASK was created
>> even when it failed.
>> In case the details are important (or if anybody has a better idea how to
>> achieve what I want): I have a raster map of subcatchemts belonging to
>> stream segments created with r.stream.basins. For the endpoints of segments,
>> I want to combine these subcatchments to a total catchment raster map
>> containing all upstream catchments.
>> Thanks a lot,
>> Mira
>> Dr. Mira Kattwinkel
>> Quantitative Landscape Ecology
>> Institute for Environmental Sciences
>> University of Koblenz-Landau
>> Fortstraße 7
>> 76829 Landau
>> Germany
>> Phone: + 49 6341 280-31553
>> Office: Building I, Room 2.02
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
>> Micha Silver
>> cell: +972-523-665918
Dr. Mira Kattwinkel
Fortstraße 7
76829 Landau
Germany
