[GRASS-user] r.terraflow problem
    Filipe Dias
    filipesdias at gmail.com
    Thu Apr 13 02:43:32 PDT 2017
Hi
I'm trying to run r.terraflow with with a SRTMGL1 dem but I am getting a
message that I can't decipher.
What am I doing wrong?
Thanks for the help
Cheers
F
(Thu Apr 13 10:40:03 2017)
r.terraflow elevation=dem_pt at fct filled=filled direction=direc
swatershed=swater accumulation=accum tci=tci
Memory manager registering memory in MM_IGNORE_MEMORY_EXCEEDED mode.
STREAM temporary files in
/media/fd/Dados/FilipeTrabalho/FCT/FCT/fct/.tmp/fd-
XPS/16123.0  (THESE INTERMEDIATE STREAMS WILL NOT BE DELETED
IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE
SPACE PLEASE DELETE THESE FILES MANUALLY!)
ami_single_temp_name: G_mkstemp() failed: : No such file or
directory
r.terraflow: ami_stream.cpp:93: int
ami_single_temp_name(const string&, char*): Assertion `0'
failed.
(Thu Apr 13 10:40:03 2017) Command finished (0 sec)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170413/b29a8109/attachment.html>
