[GRASS-user] select only patches with 1-cell width
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Thu Apr 20 11:13:57 PDT 2017
Hi Giuseppe,
Not a single command, but you could:
1. run r.grow.distance, then
2. r.neighbors with 5 pixels circular neighborhood and maximum statistics
3. r.mapcalc expression=”result=max_nbh_5<=1,1,null()”
If you want to get a vector lines result you might need r.thin and v.to.rast after that.
Hope that helps!
Cheers
Stefan
From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Giuseppe Amatulli
Sent: torsdag 20. april 2017 18.06
To: GRASS user list <grass-user at lists.osgeo.org>
Subject: [GRASS-user] select only patches with 1-cell width
I have a huge streams/lakes dataset and I want to be able to select only water bodies (streams) with 1-cell width.
In other words if i have this raster
[Inline images 1]
I want to select only this streams
[Inline images 2]
Any suggestion or grass command that does such operation.
Thank you
Best
Giuseppe Amatulli, Ph.D.
Research scientist at
Yale School of Forestry & Environmental Studies
Yale Center for Research Computing
Center for Science and Social Science Information
New Haven, 06511
Teaching: http://spatial-ecology.org
Work: https://environment.yale.edu/profile/giuseppe-amatulli/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170420/341203e1/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170420/341203e1/attachment-0002.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170420/341203e1/attachment-0003.png>
