[GRASS-user] error in t.rast.accdetect
Sören Gebbert soerengebbert at googlemail.com
Thu Apr 27 11:22:46 PDT 2017
is there already a map with the id "eip2_2003_08_01 at lst" registered in
the temporal database? The module does not check for existent maps and
simply assumes that the ids are unique.
Ciao
Sören
2017-04-27 19:22 GMT+02:00 Veronica Andreo <veroandreo at gmail.com>:
> Hello list,
> I have accumulated a daily time series of temperatures with BEDD method by
> means of t.rast.accumulate, and now, I need to identify where do the cycles
> occur and how much do they last. However, when I run t.rast.accdetect, all
> goes fine until I get this error:
> Traceback (most recent call last):
>   File
> "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/scripts/t.rast.accdetect",
> line 592, in <module>
> ERROR: Unable to execute transaction:
> INSERT INTO raster_base ( name ,creator ,mapset     ,creation_timemain()
> ,temporal_type ,id   File
> line 437, in main
> ) VALUES ('eip2_2003_08_01' ,'veroandreo' ,'lst'
> ,'2017-04-27 18:55:42.175407' ,'absolute' ,'eip2_2003_08_01 at lst') ;
> INSERT INTO raster_absolute_time ( start_time ,id ,end_time ) VALUES
> ('2003-08-01 00:00:00' ,'eip2_2003_08_01 at lst' ,'2003-08-02 00:00:00') ;
> INSERT     register_null, empty_maps, dbif)
> INTO  File
> line 479, in create_strds_register_maps
>  raster_spatial_extent ( north ,bottom ,west ,top ,proj ,east
> ,id ,south ) VALUES (2428000.000000 ,0.000000 ,4821000.000000 ,0.000000
> ,'XY' ,6309000.000000 ,'eip2_2003_08_01 at lst' ,1312000.000000) ;
> INSERT INTO raster_metadata     (map.insert(dbif)
>  max  File
> "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/temporal/abstract_map_dataset.py",
> line 283, in insert
>  ,rows ,min ,datatype ,number_of_cells
> ,cols ,ewres ,nsres ,id ) VALUES (3.000000 ,1488 ,1.000000 ,'CELL' ,1660608
> ,1116     return AbstractDataset.insert(self, dbif=dbif, execute=execute)
> ,1000.000000   File
> "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/temporal/abstract_dataset.py",
> line 403, in insert
> ,1000.000000 ,'eip2_2003_08_01 at lst') ;
> INSERT INTO raster_stds_register ( id ,registered_stds ) VALUES
> ('eip2_2003_08_01 at lst' ,NULL) ;
>     dbif.execute_transaction(statement)
>   File
> "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/temporal/core.py",
> line 1020, in execute_transaction
>     return self.connections[mapset].execute_transaction(statement)
>   File
> line 1314, in execute_transaction
>     self.cursor.executescript(statement)
> sqlite3.IntegrityError: UNIQUE constraint failed: raster_base.id
> I have no clue of what is wrong... Here are the commands I'm using (I'm
> following the example in t.rast.accumulate manual page)
> # accumulation
> t.rast.accumulate -n input=reconstructed_lst output=daily_bedd \
>  start="2003-04-01" stop="2005-09-30" \
>  cycle="6 months" offset="6 months" granularity="1 day" \
>  basename=daily_bedd suffix=gran method=bedd limits=14,32 \
>  scale=0.02 shift=-273.15 --o
> # detect cycle 1:
> t.rast.accdetect input=daily_bedd \
>   occurrence=occurrence_eip1 start="2003-04-01" stop="2005-09-30" \
>   cycle="6 months" offset="6 months" range=109,218 \
>   basename=eip1 indicator=indicator_eip1
> The maps are created (basename=eip1) and they contain data, the occurrence
> strds is also created and contains the eip1 maps, but the indicator strds is
> empty. And this one (the indicator strds) is the one needed to identify
> where do the target cycles occur.
> I would really appreciate any help and advice... please :)
> Thanks much
> Vero
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
