[GRASS-user] Change SQLite DB Column Width?
Jeshua Lacock jeshua at 3DTOPO.com
Sun Aug 6 14:56:05 PDT 2017
> On Aug 5, 2017, at 10:11 AM, Even Rouault <even.rouault at spatialys.com> wrote:
> The condition is name = 'TrailSegment_12' not type =
Doh! Thanks - I had copied in your SQL but when it didn’t work I resorted to finding more examples on the web.
The reason why your suggested SQL wasn’t working was because I wasn’t setting the database connection with <grin>:
.open /Volumes/bigy/National/transportation/PERMANENT/sqlite/sqlite.db
I was able to reconfigure the schema as you suggested, and when I re-ran the SELECT SQL command, it showed the new size:
sqlite> SELECT SQL FROM SQLITE_MASTER WHERE NAME = 'TrailSegment_Wyoming’;
But v.patch -e still wouldn’t work. I looked at the table in the GUI and it still showed the old width of the column:
So as far as I can tell this solution won’t work, which is a bummer. I ended up getting around the issue by copying a target table, dropping all rows then inserting rows from the mismatched table (essentially as Vincent suggested).
I think it would be REALLY nice if we could supply a schema when importing with v.in.ogr. Apparently it allows you to specify the columns (but not specify their data type and width?). For instance I wish something like this worked:
v.in.ogr columns="GNIS_ID varchar(80), NAME varchar(128), etc."
That way, if as long as I used the same schema for different imports, they would all be combinable without any issue.
Best,
Jeshua Lacock
Founder/Engineer
<3DTOPO.com>
GlassPrinted.com
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170806/3ff05642/attachment-0001.html>
Name: Screen Shot 2017-08-06 at 3.43.57 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170806/3ff05642/attachment-0002.png>
Name: Screen Shot 2017-08-05 at 5.42.44 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170806/3ff05642/attachment-0003.png>
