[GRASS-user] GRASS 7.2.1 for centos 7 from copr/neteler repo
Markus Neteler neteler at osgeo.org
Tue Aug 8 15:43:34 PDT 2017
Hi Laura,
On Fri, Jul 21, 2017 at 12:51 PM, Laura Poggio <laura.poggio at gmail.com> wrote:
> Dear all,
> I am trying to install GRASS 7.2.1 using the repository neteler-grass72 on a
This one:
https://copr.fedorainfracloud.org/coprs/neteler/grass72/
> machine running centos 7 [Linux version 3.10.0-514.26.2.el7.x86_64
> (builder at kbuilder.dev.centos.org) (gcc version 4.8.5 20150623 (Red Hat
> 4.8.5-11) (GCC) )]
> I get the following errors:
> Error: Package: grass-libs-7.2.1-6.fc26.x86_64 (neteler-grass72)
>            Requires: libproj.so.12()(64bit)
>            Requires: libm.so.6(GLIBC_2.23)(64bit)
>            Requires: libgdal.so.20()(64bit)
>            Requires: libcrypto.so.1.1()(64bit)
>            Requires: libpng16.so.16()(64bit)
>            Requires: libpng16.so.16(PNG16_0)(64bit)
>            Requires: libgeos-3.6.1.so()(64bit)
>            Requires: libssl.so.1.1()(64bit)
> As far as I can see it requires versions of the libraries that are not
> readily available from centos 7 repositories (including epel).
I have compiled the version in July on COPR.
https://copr.fedorainfracloud.org/coprs/neteler/grass72/builds/
Did you install beforehand
yum install epel-release
yum install gdal gdal-python gdal-devel
> I could compile grass 7.2.1 from source without problems, but I would prefer
> to use the repository if at all possible.
> What am I missing ? Do I need to compile the dependencies before in order to
> have the right versions? Are there any repositories where the rmps could be
> found?
Those two above should deliver the needed proj and gdal RPMs.
Best
Markus
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
