[GRASS-user] error in v.in.ogr with null values
Mira Kattwinkel
kattwinkel-mira at uni-landau.de
Thu Aug 17 00:07:13 PDT 2017
Dear Jonas,
thanks for your suggestion.
This looks like a useful workaround but it seems to be a more general
issue. Is it a wanted behaviour that it is not possible without tricks
to import shapes with empty table cells? As I wrote, it used to work
just fine.
All the best,
Mira
Am 16.08.2017 um 22:41 schrieb Jeshua Lacock:
>> On Aug 16, 2017, at 2:36 PM, Jeshua Lacock <jeshua at 3DTOPO.com> wrote:
>> #convert DBF to CSV file to properly handle blank fields
>> ogr2ogr -f 'CSV' fileName.csv fileName.dbf
> Ooops - first line of the example should be this instead:
> ogr2ogr -f 'CSV' fileName.csv fileName_fixed.dbf
Am 16.08.2017 um 22:36 schrieb Jeshua Lacock:
>> On Aug 15, 2017, at 10:06 AM, Mira Kattwinkel <kattwinkel-mira at uni-landau.de> wrote:
>> I was able to nail it down to empty cells in the attribute table (NULL). When filling those the error disappears.
>> Have there been any changes to v.in.ogr that may cause this behaviour? Or could this be related to OGR / GDAL?
> Hi Mira,
> I am not sure if it will work for you, but I have found that when I have empty cells, I can get around the issue by converting the file to import to CSV then back using ogr2ogr.
> For instance (I have only done this with shape files):
> #convert back to DBF
> ogr2ogr fileName_fixed.dbf fileName.csv
> #back up original DBF file before replacing:
> mv fileName.dbf fileName_original.dbf
> #then move “fixed” DBF file back to original filename:
> mv fileName_fixed.dbf fileName.dbf
> I hope this helps!
> Best,
> Jeshua Lacock
> Founder/Engineer
> <3DTOPO.com>
> GlassPrinted.com
Dr. Mira Kattwinkel
Quantitative Landscape Ecology
Institute for Environmental Sciences
University of Koblenz-Landau
Fortstraße 7
76829 Landau
Germany
Fon: + 49 6341 280-31553
