[GRASS-user] g.list ... -1073741701 cntnd
Markus Neteler neteler at osgeo.org
Sat Aug 19 08:36:51 PDT 2017
On Thu, Aug 17, 2017 at 7:12 PM, Edmund Swylan
<Edmund.Swylan at ponymail.com> wrote:
> I have taken another step back and tried winGRASS 6.4.4 Command Line.
> For Spearfish60 7.2.1 responds with 0xc000007b to `g.proj', `g.list type=rast',
> `g.list type=vect', and `v.info soils'. It seems to give a reasonable answer to
> `r.info soils'.
> 6.4.4 responds with 0xc000007b to `g.proj' and `v.info soils' and gives
> a reasonable answer to `r.info soils'. It also produces both lists.
> Don't the differences let reduce significantly the set of suspect .dlls?
Did you try this DLL tool?
https://grasswiki.osgeo.org/wiki/GRASS_Debugging#DLL_dependencies
Markus
