[GRASS-user] g.list ... -1073741701 cntnd
Helmut Kudrnovsky
hellik at web.de
Sat Aug 19 15:04:46 PDT 2017
Edmund Swylan wrote
> ES> I have taken another step back and tried winGRASS 6.4.4 Command Line.
> ES> Don't the differences let reduce significantly the set of suspect
> .dlls?
> MN> Did you try this DLL tool?
> MN> https://grasswiki.osgeo.org/wiki/GRASS_Debugging#DLL_dependencies
> I had not tried it. Now I have. To little effect. The dependencies are too
> numerous. I have tried to see what makes the v.info of winGRASS 6.4.4
> fare worse than the r.info. Taking into consideration what the relevant
> .bats do to PATH, I do not see what module might be missed by v.info but
> not by r.info (EFSADU.dll, e.g., would be missed by both.). The
> observation
> is not much use though. In the process I seem to have discovered a
> repetition
> in the PATH, a zlib1.dll - probably a copy of zlib_osgeo.dll, and (in
> 7.2.1)
> competing libintl-8.dlls
re winGRASS 6.4.4, what I can say, the grass 6.x-line isn't maintained
actively anymore. Thus, testing should be done with the 7.2.x line.
the dll-issues looks like a mismatch and mixing of dlls and their
dependencies in %PATH% variable.
AFAICT starting from scratch may be an option.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/g-list-1073741701-cntnd-tp5331698p5331889.html
Sent from the Grass - Users mailing list archive at Nabble.com.
