[GRASS-user] Re-projected Data Position Mismatch
Jeshua Lacock
jeshua at 3DTOPO.com
Tue Aug 22 16:46:13 PDT 2017
To hopefully help troubleshoot; I just reprojected one of the raster tiles (from epsg: 3857), into the source location of one of the lonlat vectors (reverse projections from my OP), and the datasets are offset by the same distances. Since the dimensions of the raster are being changed (by r.proj), it leads me to think it must be a datum or coordinate system misalignment and not a projection issue.
For example, here is a test raster tile in the Comp Projection (epsg: 3857): http://3DTOPO.com/epsg_3857.png
And in the reverse lonlat projection: http://3DTOPO.com/lonlat.png
(the raster tile should be located in the red area in both examples)
