[GRASS-user] r.damflood question
Massimiliano Cannata
massimiliano.cannata at supsi.ch
Wed Aug 30 01:56:21 PDT 2017
Hi, glad to see the module is used :-D
If I correctly remember, you have to use a DEM with bathimetry and dam,
then the dam break is passed trough a raster with decrements of dam height
(it is use to calculate the new DEM after the dam breck by DEM - BREAK).
Best,
Maxi
2017-08-30 10:44 GMT+02:00 Codrina Maria Ilie <codrina at geo-spatial.org>:
> Hi Anna,
> You were perfectly right!
> I changed from null to 0 and it works.
> Thank you!
> Codrina
> On 29/08/2017 00:05, Anna Petrášová wrote:
>> Hi,
>> On Mon, Aug 28, 2017 at 4:53 PM, Codrina Maria Ilie
>> <codrina at geo-spatial.org> wrote:
>>> Hi all,
>>> I have been trying to run GRASS7 module r.damflood using the following
>>> datasets:
>>> [https://drive.google.com/drive/folders/0B2Yx_1shUSx3VThlY3B
>>> rV1JyWjg?usp=sharing],
>>> with this command:
>>> r.damflood --overwrite --verbose elev=dem lake=water_depth
>>> dambreak=dam_breach manning=manning tstop=3 deltat=1 h=b_depth vel=b_vel
>>> hmax=b_mwd vmax=b_mwv imax=b_mi wavefront=b_wf
>>> To make it easier, the lake has a constant depth.
>>> As far as I can understand, the rasters should be correctly built, but
>>> the
>>> outputs of r.damflood are obviously wrong (rasters with nodata or one
>>> category = 0; at second 1 the depth raster is half the lake's size
>>> (s00.png,
>>> s01.png)and at second 2, it completely disappears).
>>> During the processing, I get the Courant-Friedrich-Lewy stability
>>> condition
>>> warning message.
>>> If I try to chose as computational method for initial velocity
>>> estimation,
>>> uniform drop in of lake or small dam breach, I get the following error
>>> "ERROR: Don't find the dambreak - Please select a correct map or adjust
>>> the
>>> computational region".
>>> Does anyone have an idea what could be the reason of these results,
>>> please?
>>> Any suggestion would be highly appreciated.
>> Your water_depth should have 0 instead of nulls, I think that's the
>> problem in your case. The stability condition warning probably means
>> you should reduce your time step, on the other hand, it will take more
>> time.
>> Anna
>>> Cheers,
>>> Codrina
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
*Massimiliano Cannata*
Professore SUPSI in ingegneria Geomatica
Responsabile settore Geomatica
Istituto scienze della Terra
Dipartimento ambiente costruzione e design
Scuola universitaria professionale della Svizzera italiana
Campus Trevano, CH - 6952 Canobbio
Tel. +41 (0)58 666 62 14
Fax +41 (0)58 666 62 09
*www.supsi.ch/ist <http://www.supsi.ch/ist>*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170830/2aad65b8/attachment.html>
