[GRASS-user] Copy and concatenate a vector attribute between layers
Peter Tittmann
ptittmann at gmail.com
Wed Dec 6 09:42:22 PST 2017
Thank you, Moritz.
I'm pretty familiar with SQL but can’t figure out how layer 2 is stored in the database. When I `pragma table_info(<vector>)` I only see the layer 1 attributes.
I’ll work with the GRASS approach you suggested.
Best,
Peter
> On Dec 1, 2017, at 11:53 PM, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> On 02/12/17 02:03, Peter Tittmann wrote:
>> Hi,
>> I have a vector (`POINT`) which has two layers containing relevant attributes (’strata’ and ’stand’). I would like to concatenate the two values into a new attribute for Layer 1 (’<STRATA>_<STAND>’). I’ve been struggling to sort this out for too long and am tapping out. Its probably blatantly obvious but it has escaped me.
> Probably the easiest way if your not very familiar with SQL:
> - Create a new column in layer 1 where you can put the info from layer 2
> - Fill this column with v.to.db option=query query_layer=2, etc
> - Create a second new column to hold the concatenation
> - v.db.update to update this new column with the concatenation of the two others (something like qcol = "STRATA || '_' || STAND")
> Otherwise, if there is a common key in both tables, you can just create a new column and use db.execute to launch a UPDATE TABLE directly, grabbing the info from the two table and concatenating it directly in the query.
> Moritz
>> Thank you!
>> Here are some specifics.
>> east, north: 651849.842735, 6604949.78485
>> c34_patch at project_area:
>> Type: Point
>> Layer: 1
>> Category: 21623
>> Driver: sqlite
>> Database: /Users/pete/grassdata/PortGraham/project_area/sqlite/sqlite.db
>> Table: c34_patch
>> Key_column: cat
>> Attributes:
>> cat: 21623
>> *strata: 3 — STRATA*
>> Type: Point
>> Layer: 2
>> *Category: 10 — STAND*
>> grass-user mailing list
>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/grass-user <https://lists.osgeo.org/mailman/listinfo/grass-user>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171206/c449634c/attachment.html>
