[GRASS-user] Allow setting environment variables in grass_env_file
Markus Neteler
neteler at osgeo.org
Wed Dec 6 23:53:05 PST 2017
Ken,
On Sun, Dec 3, 2017 at 2:37 PM, Ken Mankoff <mankoff at gmail.com> wrote:
> Dear GRASS List,
> In the grass72 startup script, in the function:
> def bash_startup(location, location_name, grass_env_file):
> These lines exist:
> for line in readfile(env_file).splitlines():
> if not line.startswith('export'):
> f.write(line + '\n')
> If I comment out the 2nd line (and fix the indentation for the 3rd line because this is Python), then I can add "export DYLD_LIBRARY_PATH=..." in either ~/.grass.bashrc or ~/.grass7/bashrc and this fixes various GRASS issues on OS X relating to the temporal framework.
> Can a GRASS developer explain to me why the startup scripts ignores EXPORT statements from the GRASS init file? Is there a problem if I change this behavior? Should I submit an patch to change this behavior permanently for computers other than my own?
> In more detail, this is not an issue with Fink installations, but is with MacPorts. Fink installs an OS X Application: GRASS.app. Deep in the app I found a Makefile that seems to tell GRASS.app to respect "GRASS_LD_LIBRARY_PATH". The Macports version does not install an app, and does not respect the GRASS_LD_LIBRARY_PATH variable. For some reason, shell-level LD_LIBRARY_PATH and DYLD_LIBRARY_PATH 's are also not respected (perhaps due to SIP?).
> I've switched from Fink to MacPorts because the Fink installation (on my system) has a GDAL issue and I cannot use 'r.external'. The MacPorts version allows me to use 'r.external', but I cannot use the temporal framework now, unless I edit out the line in the grass72 script.
Can you please create a ticket for this? Then the developers reading
the grass-dev mailing list will get notified instantly.
thanks
Markus
> Thanks,
> -k.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Markus Neteler, PhD
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
