[GRASS-user] i.atcorr with Sentinel2
Žofie Cimburová
zoficimburova at gmail.com
Mon Dec 18 07:13:58 PST 2017
Dear Moritz,
According to
https://earth.esa.int/web/sentinel/user-guides/sentinel-2-msi/product-types
, the L1C product I am using already is in top of atmosphere reflectance,
so this should not be the problem (?).
I tried running i.atcorr both with and without the -r flag.
Zofie
On Mon, Dec 18, 2017 at 3:35 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 18/12/17 13:14, Žofie Cimburová wrote:
>> Hi all,
>> Now the 6S parameters are complete, but the output map contains only
>> NULLs, no matter what combinations of input parameters and flags I use.
>> Have anyone encountered the same issue? (Info below.)
> In the i.atcorr man page it says:
> "If flag -r is used, the input raster data are treated as reflectance.
> Otherwise, the input raster data are treated as radiance values"
> IIUC, your data is still in DN. You might want to try to transform this
> into radiance values before sending it into i.atcorr.
> Moritz
>> Thanks again.
>> Zofie
>> Version:
>> g.version -g
>> version=7.4.0RC1
>> date=2017
>> revision=exported
>> build_date=2017-11-18
>> build_platform=x86_64-pc-linux-gnu
>> build_off_t_size=8
>> Region:
>> g.region -p
>> projection: 1 (UTM)
>> zone: 33
>> datum: etrs89
>> ellipsoid: grs80
>> north: 6653695
>> south: 6643685
>> west: 256495
>> east: 266505
>> nsres: 10
>> ewres: 10
>> rows: 1001
>> cols: 1001
>> cells: 1002001
>> Input data: Sentinel2 L1C product B02 (tried with B01 too)
>> r.info <http://r.info> map=test_B02 at p_Sentinel4Nature_S2_Oslo
>> | Map: test_B02 at p_Sentinel4Nat Date: Wed Dec 6 12:06:39 2017
>> | Mapset: p_Sentinel4Nature_S2_Oslo Login of Creator:
>> stefan.blumentr
>> | Location: ETRS_33N
>> | DataBase: /data/grass
>> | Title: S2A_OPER_PRD_MSIL1C_PDMC_20160
>> 907T044118_R008_V20160905T104022_2
>> | Timestamp: none
>> | Type of Map: raster Number of Categories: 0
>> | Data Type: CELL
>> | Rows: 1001
>> | Columns: 1001
>> | Total Cells: 1002001
>> | Projection: UTM (zone 33)
>> | N: 6653695 S: 6643685 Res: 10
>> | E: 266505 W: 256495 Res: 10
>> | Range of data: min = 1 max = 28000
>> | Data Description:
>> | generated by r.in.gdal
>> 6s file:
>> 25- geometrical conditions=Sentinel-2A
>> 9 5 10.6728 10.73413 59.90647- month day hh.ddd longitude latitude
>> 4 - atmospheric model=subarctic summer
>> 3- aerosol model=urban
>> 50- visibility [km] (aerosol model concentration) (this is estimated, I
>> also tried with AOD specified)
>> -0.055- mean target elevation above sea level [km]
>> -1000- sensor height
>> 166- Sentinel2A Blue band B2 (440nm - 535nm)
>> Command:
>> i.atcorr input=test_B02 at p_Sentinel4Nature_S2_Oslo range=1,28000
>> elevation=dem_10m_25833 at p_Sentinel4Nature_S2_Oslo parameters=/home/
>> NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt <
>> http://NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt>
>> output=test_B02_atcorr
>> >Atmospheric correction...
>> >Atmospheric correction complete.
>> (I am not sure about the range parameter, tried with 0,255 too. The DEM
>> contains no NULLs. Also tried running with -r and -a flags.)
>> Output:
>> r.info <http://r.info> map=test_B02_atcorr at p_Sentinel4Nature_S2_Oslo
>> | Map: test_B02_atcorr at p_Sentinel4N Date: Mon Dec 18 13:10:14
>> 2017
>> zofie.cimburova
>> | Location: ETRS_33N
>> | Title: test_B02_atcorr2
>> | Timestamp: none
>> | Data Type: FCELL
>> | Rows: 1001
>> | Columns: 1001
>> | Range of data: min = -nan max = -nan
>> | Data Description:
>> | generated by i.atcorr
>> | Comments:
>> | i.atcorr input="test_B02 at p_Sentinel4Nature_S2_Oslo" range=1,28\
>> | 000 elevation="dem_10m_25833 at p_Sentinel4Nature_S2_Oslo" para\
>> | meters="/home/NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt
>> <http://NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt>" o\
>> | utput="test_B02_atcorr2" rescale=0,255
>> On Fri, Dec 15, 2017 at 5:12 PM, Žofie Cimburová <zoficimburova at gmail.com
>> <mailto:zoficimburova at gmail.com>> wrote:
>> Dear Markus,
>> thanks for your reply, this is exactly what I need to know!
>> Best, Zofie
>> On Fri, Dec 15, 2017 at 5:09 PM, Markus Neteler <neteler at osgeo.org
>> <mailto:neteler at osgeo.org>> wrote:
>> On Dec 15, 2017 3:54 PM, "Žofie Cimburová"
>> <zoficimburova at gmail.com <mailto:zoficimburova at gmail.com>> wrote:
>> > Dear all,
>> > I am trying to use i.atcorr (GRASS 7.4) to apply atmospheric
>> corrections for Sentinel 2 data. The documentation provides a great help,
>> but there are two points I am not sure about - >
>> > - I don't need the atmospheric correction to be applied to the
>> whole scene, so I only imported a small clip of the scene to GRASS. What
>> longitude and latitude shall I then specify in the 6S parameters?
>> I'd use the center coordinates of the clipped area.
>> > Or is it necessary to apply the corrections to the entire scene?
>> No since it is a pixel based algorithm.
>> > - How can I estimate the value of visibility (aerosol model
>> concentration)?
>> There are AERONET data online somewhere which might be the best
>> choice.
>> Markus
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171218/23387745/attachment.html>
