[GRASS-user] i.atcorr with Sentinel2
Moritz Lennert
mlennert at club.worldonline.be
Mon Dec 18 08:06:01 PST 2017
See also discussion here:
http://forum.step.esa.int/t/the-quantification-value-has-a-true-value-dn-to-toa-reflectance/1220/
On 18/12/17 16:57, Moritz Lennert wrote:
> On 18/12/17 16:35, Stefan Blumentrath wrote:
>> Hi Moritz,
>> Thanks for helping with troubleshooting!
>> QUANTIFICATION_VALUE is 10000, Thus dividing with it gives a maximum value of 2.8...
>> Any idea how to figure out if it is 12 or 16 bit image. It is directly downloaded from ESA...
> Check which proportion of the image is > 1. AFAIR (which is a bit
> limited), you might have reflectances above 1 in saturated pixels. I
> just checked on a random image and I also have some pixels above 1, but
> only 0.25% of the pixels:
> GRASS 7.5.svn (UTM32N):/data/home/mlennert > r.mapcalc "test =
> if(b04_refl>1,1,0)"
> 100%
> GRASS 7.5.svn (UTM32N):/data/home/mlennert > r.stats -cp test
> 100%
> 0 120259106 99.75%
> 1 301294 0.25%
> And all the pixels with value 1 are in clouded areas.
> Moritz
>> Cheers
>> Stefan
>> -----Original Message-----
>> From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Moritz Lennert
>> Sent: mandag 18. desember 2017 16.26
>> To: Žofie Cimburová <zoficimburova at gmail.com>
>> Cc: GRASS user list <grass-user at lists.osgeo.org>
>> Subject: Re: [GRASS-user] i.atcorr with Sentinel2
>> On 18/12/17 16:13, Žofie Cimburová wrote:
>>> Dear Moritz,
>>> According to
>>> https://earth.esa.int/web/sentinel/user-guides/sentinel-2-msi/product-
>>> types , the L1C product I am using already is in top of atmosphere
>>> reflectance, so this should not be the problem (?).
>>> I tried running i.atcorr both with and without the -r flag.
>> Reflectance is the percentage of light that is reflected either from the top of the atmosphere or from the surface. Reflectance values should thus be real values between 0 and 1. Your data have
>> Range of data: min = 1 max = 28000
>> This means that they are expressed in digital (integer) numbers. Try transforming these DN into real numbers. IIRC, in the metadata, you have a variable QUANTIFICATION_VALUE. Divide your pixel values by that value to get real TOA reflectance values.
>> AFAIK, it also depends on whether you directly imported the original 12-bit file, or possibly a modified, e.g. 16-bit, version.
>> Moritz
>>> On Mon, Dec 18, 2017 at 3:35 PM, Moritz Lennert
>>> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
>>> On 18/12/17 13:14, Žofie Cimburová wrote:
>>> Hi all,
>>> Now the 6S parameters are complete, but the output map contains
>>> only NULLs, no matter what combinations of input parameters and
>>> flags I use. Have anyone encountered the same issue? (Info
>>> below.)
>>> In the i.atcorr man page it says:
>>> "If flag -r is used, the input raster data are treated as
>>> reflectance. Otherwise, the input raster data are treated as
>>> radiance values"
>>> IIUC, your data is still in DN. You might want to try to transform
>>> this into radiance values before sending it into i.atcorr.
>>> Moritz
>>> Thanks again.
>>> Zofie
>>> Version:
>>> g.version -g
>>> version=7.4.0RC1
>>> date=2017
>>> revision=exported
>>> build_date=2017-11-18
>>> build_platform=x86_64-pc-linux-gnu
>>> build_off_t_size=8
>>> Region:
>>> g.region -p
>>> projection: 1 (UTM)
>>> zone: 33
>>> datum: etrs89
>>> ellipsoid: grs80
>>> north: 6653695
>>> south: 6643685
>>> west: 256495
>>> east: 266505
>>> nsres: 10
>>> ewres: 10
>>> rows: 1001
>>> cols: 1001
>>> cells: 1002001
>>> Input data: Sentinel2 L1C product B02 (tried with B01 too)
>>> r.info <http://r.info> <http://r.info>
>>> map=test_B02 at p_Sentinel4Nature_S2_Oslo
>>> | Map: test_B02 at p_Sentinel4Nat Date: Wed Dec 6
>>> 12:06:39 2017
>>> | Mapset: p_Sentinel4Nature_S2_Oslo Login of Creator:
>>> stefan.blumentr
>>> | Location: ETRS_33N
>>> | DataBase: /data/grass
>>> | Title:
>>> S2A_OPER_PRD_MSIL1C_PDMC_20160907T044118_R008_V20160905T104022_2
>>> | Timestamp: none
>>> | Type of Map: raster Number of Categories: 0
>>> | Data Type: CELL
>>> | Rows: 1001
>>> | Columns: 1001
>>> | Total Cells: 1002001
>>> | Projection: UTM (zone 33)
>>> | N: 6653695 S: 6643685 Res: 10
>>> | E: 266505 W: 256495 Res: 10
>>> | Data Description:
>>> | generated by r.in.gdal
>>> 6s file:
>>> 25- geometrical conditions=Sentinel-2A
>>> 9 5 10.6728 10.73413 59.90647- month day hh.ddd longitude latitude
>>> 4 - atmospheric model=subarctic summer
>>> 3- aerosol model=urban
>>> 50- visibility [km] (aerosol model concentration) (this is
>>> estimated, I also tried with AOD specified)
>>> -0.055- mean target elevation above sea level [km]
>>> -1000- sensor height
>>> 166- Sentinel2A Blue band B2 (440nm - 535nm)
>>> Command:
>>> i.atcorr input=test_B02 at p_Sentinel4Nature_S2_Oslo range=1,28000
>>> elevation=dem_10m_25833 at p_Sentinel4Nature_S2_Oslo
>>> parameters=/home/NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt
>>> <http://NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt>
>>> <http://NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt>>
>>> output=test_B02_atcorr
>>> >Atmospheric correction...
>>> >Atmospheric correction complete.
>>> (I am not sure about the range parameter, tried with 0,255 too.
>>> The DEM contains no NULLs. Also tried running with -r and -a
>>> flags.)
>>> Output:
>>> map=test_B02_atcorr at p_Sentinel4Nature_S2_Oslo
>>> | Map: test_B02_atcorr at p_Sentinel4N Date: Mon Dec 18
>>> 13:10:14 2017
>>> zofie.cimburova
>>> | Location: ETRS_33N
>>> | Title: test_B02_atcorr2
>>> | Timestamp: none
>>> | Data Type: FCELL
>>> | Rows: 1001
>>> | Columns: 1001
>>> | Range of data: min = -nan max = -nan
>>> | Data Description:
>>> | generated by i.atcorr
>>> | Comments:
>>> | i.atcorr input="test_B02 at p_Sentinel4Nature_S2_Oslo"
>>> range=1,28\
>>> | 000 elevation="dem_10m_25833 at p_Sentinel4Nature_S2_Oslo"
>>> para\
>>> meters="/home/NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt <http://NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt>
>>> <http://NINA.NO/zofie.cimburova/Sentinel4Nature/DATA/6s.txt>>" o\
>>> | utput="test_B02_atcorr2" rescale=0,255
>>> On Fri, Dec 15, 2017 at 5:12 PM, Žofie Cimburová
>>> <zoficimburova at gmail.com <mailto:zoficimburova at gmail.com>
>>> <mailto:zoficimburova at gmail.com>>> wrote:
>>> Dear Markus,
>>> thanks for your reply, this is exactly what I need to know!
>>> Best, Zofie
>>> On Fri, Dec 15, 2017 at 5:09 PM, Markus Neteler
>>> <neteler at osgeo.org <mailto:neteler at osgeo.org>
>>> <mailto:neteler at osgeo.org <mailto:neteler at osgeo.org>>> wrote:
>>> On Dec 15, 2017 3:54 PM, "Žofie Cimburová"
>>> <mailto:zoficimburova at gmail.com> <mailto:zoficimburova at gmail.com
>>> > Dear all,
>>> > I am trying to use i.atcorr (GRASS 7.4) to apply
>>> atmospheric corrections for Sentinel 2 data. The documentation
>>> provides a great help, but there are two points I am not sure
>>> about - >
>>> > - I don't need the atmospheric correction to be
>>> applied to the whole scene, so I only imported a small clip of
>>> the scene to GRASS. What longitude and latitude shall I then
>>> specify in the 6S parameters?
>>> I'd use the center coordinates of the clipped area.
>>> > Or is it necessary to apply the corrections to the
>>> entire scene?
>>> No since it is a pixel based algorithm.
>>> > - How can I estimate the value of visibility (aerosol
>>> model concentration)?
>>> There are AERONET data online somewhere which might be
>>> the best
>>> choice.
>>> Markus
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
>>> <https://lists.osgeo.org/mailman/listinfo/grass-user>
