[GRASS-user] Contours
Rich Shepard rshepard at appl-ecosys.com
Mon Dec 18 09:38:16 PST 2017
On Mon, 18 Dec 2017, Shane Carey wrote:
> I have a large DTM (5m cell size) and it covers an area of 100,000km2. I
> need to create contours every 10meters in the dataset. If I tile the
> dataset and contour each tile, the data, the contours act funny at the
> edges, hence the need to process the area as one area. Is grass capable of
> doing this?
Shane,
   Yes. As long as you have sufficient memory and drive space. You can always
set the environment variable in ~/.bash_profile:
export=GRASS_VECTOR_LOWMEM=1
which will use available memory and not crash, while running more slowly.
   If I'm wrong I'm sure we'll both read about it. :-)
HTH,
Rich
