[GRASS-user] i.atcorr with Sentinel2
Sajid Pareeth
spareeth at gmail.com
Tue Dec 19 06:58:31 PST 2017
Hi Stefan
I tried with your data, and it works for me.
Check the output here:
http://www.scientificpubs.com/data_share/s2a_b8_corr.tif.tar.gz
I am running it in Ubuntu 16.04, and GRASS latest trunk version, inside a
EPSG:25833 location.
I will send you the other clipped data from my study area, shortly.
Regards
Sajid
On Tue, Dec 19, 2017 at 3:31 PM, Stefan Blumentrath <
Stefan.Blumentrath at nina.no> wrote:
> Forgot to mention, my test data is tiny (< 3MB)…
> *From:* grass-user [mailto:grass-user-bounces at lists.osgeo.org] *On Behalf
> Of *Stefan Blumentrath
> *Sent:* tirsdag 19. desember 2017 15.24
> *To:* Sajid Pareeth <spareeth at gmail.com>
> *Cc:* GRASS user list <grass-user at lists.osgeo.org>
> *Subject:* Re: [GRASS-user] i.atcorr with Sentinel2
> Dear Sajid,
> Thanks so much for your reply and confirming that the module works in
> principle!
> Would you be able to provide me with the 1000 X 1000 clip of your data, so
> I can check if it is my installation?
> I tried also two different boxes and GRASS versions (Ubunut 14.04 with
> GRASS 7.3 and 7.4 compiled from source and Ubuntu 16.04 with GRASS 7.4 from
> UbuntuGIS) and none of it worked.
> Also, altering the terrain model from floating point with negative values
> to integer without negative values did not change a thing…
> I still get only NULL pixels…
> In case someone would be willing to test my data (which I would be very
> grateful for), you can get it directly here:
> dem: http://www.filedropper.com/dem_1
> S2 band 8: http://www.filedropper.com/s2aoperprdmsil1cpdmc20160907t0
> 44118r008v20160905t10402220160905t104245b08
> 62 params: http://www.filedropper.com/p6s
> I also have it on FTP and can share username and password offlist…
> Cheers
> Stefan
> *From:* Sajid Pareeth [mailto:spareeth at gmail.com <spareeth at gmail.com>]
> *Sent:* tirsdag 19. desember 2017 12.51
> *To:* Stefan Blumentrath <Stefan.Blumentrath at nina.no>
> *Cc:* Moritz Lennert <mlennert at club.worldonline.be>; Žofie Cimburová <
> zoficimburova at gmail.com>; GRASS user list <grass-user at lists.osgeo.org>
> To add, I have used the input as such with out applying the quantification
> value.
> >> 6s file:
> >> 25- geometrical conditions=Sentinel-2A
> >> 9 5 10.6728 10.73413 59.90647- month day hh.ddd longitude
> latitude
> >> 4 - atmospheric model=subarctic summer
> >> 3- aerosol model=urban
> >> 50- visibility [km] (aerosol model concentration) (this is
> >> estimated, I also tried with AOD specified)
> >> -0.055- mean target elevation above sea level [km]
> >> -1000- sensor height
> >> 166- Sentinel2A Blue band B2 (440nm - 535nm)
> Just noticed, the last parameter should be 167 for Sentinel B2.
> Sajid
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171219/8317a39e/attachment-0001.html>
