[GRASS-user] i.atcorr with Sentinel2
Sajid Pareeth spareeth at gmail.com
Tue Dec 19 09:44:03 PST 2017
Hi
> but I get only NULL values also for those data and settings and when
> running i.atcorr in GRASS 7.4.0RC1.
That's strange !!!
> I stumbled over the following line in i.atcorr output (see full verbose
> output below):
> *    view zenith angle:     0.00 deg  view azimuthal angle:         0.00
> deg   *
> Do you get that as well?
Yes, I am getting the same atmospheric model description.
> Sajid, can you send me the output of your
> grass75 --config
Here it is:
x86_64-pc-linux-gnu
> ./configure  --enable-largefile=yes --with-nls --with-cxx --with-readline
> --with-proj-share=/usr/share/proj --with-geos=/usr/bin/geos-config
> --with-python=yes --with-wxwidgets --with-cairo --with-fftw
> --with-opengl-libs=/usr/include/GL --with-freetype=yes
> --with-freetype-includes=/usr/include/freetype2/ --with-postgresql=yes
> --with-postgres-includes=/usr/include/postgresql --with-sqlite=yes
> --with-mysql=yes --with-mysql-includes=/usr/include/mysql
> gcc
> /usr/local/src/grass7_trunk/dist.x86_64-pc-linux-gnu
> 70829
> 7.5.svn
Hope it helps.
Sajid
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171219/81d55052/attachment.html>
