[GRASS-user] i.atcorr with Sentinel2
Markus Neteler neteler at osgeo.org
Tue Dec 19 13:17:08 PST 2017
On Tue, Dec 19, 2017 at 9:58 PM, Micha Silver <tsvibar at gmail.com> wrote:
> Dear Stefan:
> I also tried your data, and failed. Any values for the geom (first line in
> the 6S parameters) above 24 cause this error:
(there is a comment inside - likely not supported to have that in the
parameter file)
> GRASS 7.2.2 (SB):~/work/tmp/Blumentrath > g.version
> GRASS 7.2.2 (2017)
> GRASS 7.2.2 (SB):~/work/tmp/Blumentrath > cat p6s.txt
> 25    # originally 25
> 9 5 10.6728 10.73413 59.90647
> 4
> 3
> 50
> -0.055
> -1000
> 165    # original 173
> GRASS 7.2.2 (SB):~/work/tmp/Blumentrath > i.atcorr --v -r --o input=S2A.B08
> elev=dem output=test_atcorr param=p6s.txt range=1,10000 rescale=1,10000
> ERROR: Unsupported/unreadable format in control file (found igeom=25)
... probably caused by the # comment? I'd put values only.
Markus
