[GRASS-user] Level LiDAR data to gps points
Vaclav Petras
wenzeslaus at gmail.com
Wed Dec 27 15:14:03 PST 2017
[cc'ing the list]
One way to do the spatially variable shift is to do what I suggested
earlier, but instead of the last step (computing average), interpolate a
surface from the differences at each point using, e.g., v.surf.rst with
zcolumn option set to the difference column computed earlier. For the
average, the assumption was that the shift is everywhere the same. Here,
the assumption is that you can interpolate in between the points, i.e. that
the interpolated values are meaningful. This assumption might be broken
e.g. when some abrupt surface change influenced the vertical shift of the
lidar points in a specific area/around certain GPS point (unlikely case).
To actually shift the data, you need to either do the calculation in the
attribute table (using the aforementioned modules such as v.db.update) or
more simply, and likely more efficiently, apply the shift to a raster with
binned elevations from r.in.lidar using r.mapcalc (same expression as
before, just with a raster map name instead of a constant).
On Wed, Dec 27, 2017 at 5:22 PM, Shane Carey <careyshan at gmail.com> wrote:
> Oh super Vaclav, is there a way of doing a spatially variable shift or can
> you only do a block shift?
> Thanks for your help :-)
> On Wed, Dec 27, 2017 at 4:42 PM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
>> On Tue, Dec 19, 2017 at 3:29 AM, Shane Carey <careyshan at gmail.com> wrote:
>>> I have some LiDAR data that was not levelled properly and I was
>>> wondering does anybody know of a way of levelling the las files to gps
>>> points?
>> Hi,
>> if the issue is really just vertical (which is usually the case), you can
>> use v.transform zshift to shift by the given value. For rasters, e.g. DEM
>> based on binning the lidar points with r.in.lidar, you can use r.mapcalc to
>> shift it (e.g. expression "new = old + 2").
>> The shift can be determined by binning (or even interpolating) the
>> points, followed by querying raster using the GPS points as a vector using
>> v.what.rast, and then by computing the difference using v.db.addcolumn and
>> v.db.update. Finally, you can average the difference using v.db.univar. One
>> (average) values will be usually good enough for lidar point cloud, for UAV
>> point cloud, spatially variable shift might be needed.
>> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171227/14977668/attachment.html>
