[GRASS-user] r.sun.daily with multiple CPU cores: error uncompressing raster data ...
    Markus Metz
    markus.metz.giswork at gmail.com
    Sat Dec 30 14:32:38 PST 2017
On Fri, Dec 29, 2017 at 5:07 PM, Dylan Beaudette <dylan.beaudette at gmail.com>
wrote:
> Hi everyone,
> First of all, thanks in advance for the r.sun.daily module which is a
> nice replacement for my amateurish attempts over the last 12 years.
> I am currently working on an annual beam radiance map for a large
> geographic region, at 30m res: 70,953 x 46,964 cells. This is far too
> large for a single pass of r.horizon or r.sun on my machine so I have
> split the data into 5,000 x 5,000 cell tiles with 100 cells of
> overlap. This seems to be sufficient for my purposes and the edge
> effects are tolerable.
> At 8-15 minutes / tile / day (r.sun) and 54 tiles this job calls for
> multiple CPU cores. All of the parallel processing that I use is (as
> far as I know) contained within the same region.
> I have had good success with running r.horizon in parallel via GNU
> parallel like this:
> # 1: start angle
> # 2: angle step
> # 3: elevation tile
> seq 0 $step 330 | parallel --gnu --progress "bash make-hz-maps.sh {}
> $step $elev"
> Which is just a wrapper around r.horizon and run in parallel "within"
tiles.
> Next, I run r.sun.daily (8 CPU cores) within tiles:
> r.sun.daily --overwrite elevation=$elev aspect=$asp slope=$slope \
> start_day=1 end_day=365 beam_rad=$beam horizon_basename=hzangle
> horizon_step=$step nprocs=8
> The r.sun.daily modules finishes without error about 50-60% of the
> time, results look good. The other 50-40% of the the time I get this:
> ERROR: Error uncompressing raster data for row 2605 of
>        <r_sun_crop8255_beam_rad_tmp_352>
> *** buffer overflow detected ***: g.message terminated
> ======= Backtrace: =========
> /lib/x86_64-linux-gnu/libc.so.6(+0x7329f)[0x7f8b9a70129f]
> /lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x5c)[0x7f8b9a79c83c]
> /lib/x86_64-linux-gnu/libc.so.6(+0x10d710)[0x7f8b9a79b710]
> /lib/x86_64-linux-gnu/libc.so.6(+0x10cc19)[0x7f8b9a79ac19]
> /lib/x86_64-linux-gnu/libc.so.6(_IO_default_xsputn+0xbc)[0x7f8b9a70961c]
> /lib/x86_64-linux-gnu/libc.so.6(_IO_vfprintf+0x1cc5)[0x7f8b9a6d9905]
> /lib/x86_64-linux-gnu/libc.so.6(__vsprintf_chk+0x84)[0x7f8b9a79aca4]
> /usr/local/grass-7.5.svn/lib/libgrass_gis.7.5.svn.so
(+0x1343c)[0x7f8b9aa6a43c]
(G_fatal_error+0xbf)[0x7f8b9aa6accf]
> g.message(main+0x254)[0x400dd4]
> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7f8b9a6aff45]
> g.message[0x400ea2]
> I can't seem to replicate the problem, as subsequent runs with the
> same parameters and in the same tile are successful! This leads me to
> think that:
> * some aspect of this approach is not thread safe
> * there is something wrong with my computer
> * there is a subtle bug in the raster writing / reading code when
> invoked in parallel
> I have encountered similar raster reading errors in the past,
> typically in the context of parallel processing:
> https://trac.osgeo.org/grass/ticket/2762
> https://trac.osgeo.org/grass/ticket/2764
http://osgeo-org.1560.x6.nabble.com/Error-reading-raster-data-for-row-xxx-only-when-using-r-series-and-t-rast-series-td5229569i20.html
> https://lists.osgeo.org/pipermail/grass-dev/2015-July/075691.html
> Here is some information on my system and version of GRASS:
>  ./configure  --enable-64bit --with-libs=/usr/lib --without-pthread
> --without-odbc --without-mysql --with-readline --with-cxx
> --enable-largefile --with-freetype
> --with-freetype-includes=/usr/include/freetype2 --with-sqlite
> --with-python --with-geos=/usr/local/bin/geos-config --without-opencl
> --with-opencl-includes=/usr/include/CL/ --with-postgres
> --with-postgres-includes=/usr/include/postgresql/
> --with-postgres-libs=/usr/lib/
> --with-proj-share=/usr/local/share/proj/
> version=7.5.svn
> date=2017
> revision=r71964
> build_date=2017-12-21
> build_platform=x86_64-pc-linux-gnu
> build_off_t_size=8
> Any ideas?
Please try the patch attached to ticket #2764 helps to get closer to the
problem.
Markus M
> I haven't had a chance to inspect the maps in question as r.sun.daily
> deletes the intermediate pieces on error.
> Thanks!
> Dylan
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171230/eda6f8ba/attachment.html>
